Emergency procedures when sinking - SailNet Community
post #1 of 16 Old 11-30-2010 Thread Starter
Learning to sail
One thing I've wondered a lot when sailing around in my new-to-me boat is what I'd do if the boat developed a serious leak that was not easy to fix. We sail in the Sam Framcisco Bay, a semi-protected bay, never far from land, and have good lifejackets, a VHF radio, and the usual safety gear, so I'm not really worried about personal safety. The main thing I don't know is what to do to save the boat.
Obviously fixing a leak by jamming something or other into the leaky part of the hull is the best, but there's a wide category of leak types that I know I wouldn't be able to effectively seal within a reasonable amount of time, such as situations where it's hard to find the leak, where there isn't good access to the leak location, where the hole is large, etc.
One strategy that occurred to me is attempting to ground the boat. In our part of the bay, we're never far from shallow water. I think this would only be effective near high tide, as the daily tidal range around here is around seven feet. I'm not sure if trying to ground the boat could have some unintended effect that would be worse...
Any thoughts?
aaronwindward is offline
post #2 of 16 Old 11-30-2010
If you can find an area with a clear sand or mud bottom that is shallow enough, preferably without strong surf, grounding the boat is an excellent solution to saving it from sinking. Even at low tide, doing so is a good idea, because it gives you time to find and slow the leak, which you wouldn't have otherwise. Also, as the tide rises, there's no reason you can't keep kedging the boat further aground.
Doing so on rockier or debris strewn bottom will still give you more options, but may also result in more damage to the hull, so is not as useful an approach. Same with doing so in areas with heavy surf.
One issue to watch for is that the boat lies down correctly when the tide starts to drop. If the boat lies careened over too far, you stand a good chance of having the boat downflood before it starts to float when the tide returns. The mast needs to be pointed upwards and preferably towards the shallower waters. You can often help the boat do this by laying out kedge anchors and using them to tip the boat in the right direction as the tide recedes. Of course, if you have twin keels or a wing keel, this may not be necessary.
If you do so at near high tide, with a seven foot tidal range, there's a good chance you'll be able to work on the hull from the outside and get a temporary patch over the damaged area. Carrying epoxy putty that cures underwater, like MarineTex, helps in making emergency repairs.
sailingdog is offline
post #3 of 16 Old 11-30-2010
Chastened
Ajax_MD's Avatar
I'm in agreement with the grounding strategies, but let's talk for a moment as if grounding were not an option-
1. If you haven't already, buy a package of wooden bungs and tie the appropriate size bung to each thru-hull with a length of twine. That way, the appropriate damage control item is already in place if a seacock or thru-hull fails.
2. A Forespar foam damage control plug. I bought one of these from my local chandlery. It's essentially a large, red Nerf cone. If you drag on a rock, or hit a floating object that causes a gash in the hull, you can jam the cone lengthwise into the gash. You can cut it up as necessary to fit small punctures. You can jam it into thru-hulls, etc. It's very versitile.
3. A "belly band". Keep a tarp or an old sail onboard with grommets alone the edges, and lines run through the grommets. If you incur a puncture that the Forespar plug just can't seal, you can jump overboard, and place this tarp or fabric over the hole. Water pressure will shove it right into the hole. You bring the lines up to the deck and tie it off.
You can add Marine-Tex around the perimeter of the hole from inside the boat to really seal it up, or if time allows, you can smear Marine-Tex around the perimeter of the hole from outside, and then slap the belly band over the hole.
I rode nuclear submarines for 11 years and you wouldn't believe how crude some of our damage control equipment was. Marlin, wood plugs, "strongbacks" (cut sections of steel pipe with rubber backing), and "Band-It" kits. Marlin and wood swells when wet. This stuff works but it requires that you be imaginative and quick.
I envision an actual "procedure" on a sailboat would go something like this:
1. "Thunk". sound of inrushing water.
2. Call away the casualty. Immediately wake up those down below.
3. Immediately engage the bilge pump and start the engine, steer a course to land.
4. Get someone on the manual bilge pump as well.
5. Locate the source of the flooding.
6. Assess the best method to stop the flooding and implement it:
a) Wooden bung/Marlin rope.
b) Forespar foam plugs.
c) Grounding.
d) Belly Band.
7. Inform the CG or nearest maritime authority of your situation and position.
8. Don PFD's and the dink or liferaft for escape if necessary.
Assuming that you're successful in plugging the leak, post-casualty procedures might go something like this:
1. De-water the boat as much as possible.
2. Update the CG or maritime authority on your position and status.
3. Work carefully to improve or secure the integrity of the repair.
4. Station a watch to monitor the breach to ensure that the repair holds.
5. Continue by fastest means to the nearest safe port to effect permanent repairs.
Now before some seriously religious world-cruiser jumps my arse for my very imperfect casualty plan, this is just something easy off of the top of my head for local, recreational sailing NOT, NOT, NOT, blue-water sailing. Also, these steps are meant to be taken simultaneously if possible, and the order is not completely representative of their priority. If you're singlehanding, well... you're going to have your hands full trying to do all of this by yourself.
I didn't mention an EPIRB because the OP is just locally cruising around or daysailing and may not want to invest in an EPIRB. An EPIRB isn't going to save your boat anyway and is often an excuse to just give up, and sit around in a rubber boat, waiting for the cavalry to come and get you.
Be resourceful, be determined, don't give up the ship.
1981 Tartan 33 #168
Ajax_MD is online now
post #4 of 16 Old 11-30-2010
BTW, I wrote a slightly longer version of my previous post on my blog...
post #5 of 16 Old 11-30-2010
Moderator
JohnRPollard's Avatar
It's a good question and one that all sailors should give some thought to - even coastal sailors like the O.P. There are lots of good suggestions here, too.
However, the suggestion to ground the boat or steer the boat toward land is debatable. Unless the area where you plan to ground the boat is soft and immediately adjacent, I would not attempt either.
When a boat gets holed or otherwise springs a leak (failed hardware, etc), the VERY FIRST action to be taken by the crew is to bring the boat to a full stop. Stopping the boat dead, will reduce the hydrostatic pressure tremendously and stem the ingress of water significantly. This single action alone may buy you more time than almost all the others combined.
Under power, it's a question of cutting the engines to neutral, but letting them continue to idle. Under sail, it would usually be best to immediately heave to so no time is wasted striking sails.
If after inspection the source of water is found to be offset on the hull, another option available to sailors might be to tack the boat over and heal the boat enough to raise the hole out of the water.
So, I like the idea of having a standing procedure, like Bubblehead's checklist. But I would change #2 to "Stop the boat: Idle engines or heave to", and adjust the other items in the list accordingly.
JohnRPollard is offline
post #6 of 16 Old 11-30-2010
Chastened
Ajax_MD's Avatar
You know John, that's a really good point. My "drive towards land" step is borne out of my power boat background and my Navy training.
Comparitively speaking, a sailboat is so slow, that the reward of getting closer to shore is offset by the increase in flooding, so heaving-to may really be better. I think individual circumstances may dictate. If you're really close to a sandy or muddy bottom, I'd go for it. Otherwise, probably not.
Heeling the boat over to get the hole out of the water or higher in the water is a great idea too. As a kid, I holed my 12' aluminum john-boat, and did exactly that to get back home.
1981 Tartan 33 #168
post #7 of 16 Old 11-30-2010
Moderator
Originally Posted by BubbleheadMd View Post
... I think individual circumstances may dictate. ...
BH,
I definitely agree about the "individual circumstances". In the Chesapeake for instance -- with the soft bottom, minimal tide range, and often close proximity of shoal water -- putting your boat aground may actually be a viable strategy (sometimes).
But since we are discussing emergency procedures more generically, it's important to emphasize bringing the boat to a dead stop and slowing the ingress of water. Not everybody will have our luxury of shallow water and a soft bottom immediately nearby.
post #8 of 16 Old 11-30-2010
I would also suggest, start the engine while you still can. Diesels are happy to run until the air intake is submerged but starter motors less likely.
Starting the engine also ensures full voltage for your radio (best range) and any pumps or lights you may need.
hellosailor is offline
post #9 of 16 Old 11-30-2010
+1
post #10 of 16 Old 11-30-2010
Assuming you can get the boat somewhere for help, then what?
I've been thinking about how to handle a sinking situation on our boat. We're on a smallish lake, so getting the boat to somewhere for help is a reasonable possibility. But our marina does not have haul out capabilities, and the one that does is not open on weekends. I imagine being out for a long weekend, and not being able to get a haul out until Tuesday morning.
It doesn't seem helpful to take the boat home just to have it sink in its slip. I guess one might be able to get a high volume pump at dock. Otherwise, grounding it seems the only option.
s/v Dancing Days
Beneteau 31
Lewisville Lake, TX
bacampbe is offline
docking procedures KeltiC Learning to Sail 70 07-04-2010 03:56 AM
top five cleaners and procedures w1651 General Discussion (sailing related) 1 05-26-2010 08:07 PM
U.S. Customs procedures on Cape Cod? wnor Cruising & Liveaboard Forum 10 08-30-2008 04:06 PM
USCG radio procedures jrd22 General Discussion (sailing related) 88 10-11-2007 05:40 PM
Selling Procedures haist Boat Review and Purchase Forum 2 03-16-2001 07:36 AM
