offshore plotting sheets - SailNet Community
post #1 of 13 Old 12-04-2010 Thread Starter
Question offshore plotting sheets
I will be cruising from Norfolk to Bermuda in June and am wondering what would be the best way to create or buy a blank chart to draw in the location of the Gulf Stream and its eddies. The NOAA Newport-Bermuda chart does not work for my route. I was thinking of just drawing my own plotting sheet(s) on large paper with a lat-long grid but I would be interested in what others have done. Thanks for any input!
Paul
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
The secret to sailing is good judgment. Good judgment comes from experience. Experience comes from bad judgment.
okapi3 is offline
post #2 of 13 Old 12-05-2010
St Anna's Avatar
Paul
Yes, perfect way to do it. Keep the sheet and use it again, just make a new start point when needed. Use a scale to show you have actually moved, or it can be depressing!
St Anna is offline
post #3 of 13 Old 12-05-2010
You need a Universal Plotting Sheet like these.
DMA Misc.
dsmylie is offline
post #4 of 13 Old 12-06-2010
Omatako's Avatar
This is what I keep in the chart table
If you want a printable copy, PM me and I'll send you the file.
Arthur C. Clarke
Omatako is offline
post #5 of 13 Old 12-06-2010
AdamLein's Avatar
Bowditch has instructions for drawing a plotting sheet from scratch. Don't remember where, though.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #6 of 13 Old 12-06-2010
jackdale's Avatar
There are some on line.
Here is one:
http://www.cse.yorku.ca/~amana/perso...ttingSheet.pdf
Jack
jackdale is offline
post #7 of 13 Old 12-06-2010
RichH's Avatar
"Base" charts/maps for plotting purposes, etc. from NOAA: Ocean Prediction Center--Atlantic Base Map
Just select the one that best suits your needs and scale it up/down or 'crop' in a 'grafix program' to get the 'size' you want.
RichH is online now
post #8 of 13 Old 12-06-2010
Mermaid Hunter
SVAuspicious's Avatar
The base maps from OPC look good. I'll look at plotting them out on C-size paper.
I've used pilot charts in the past.
SVAuspicious is offline
post #9 of 13 Old 12-08-2010 Thread Starter
Thank you! You guys are awesome! Problem solved.
Paul
P.S. Auspicious, what is a "cut and paste" sailor?
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
okapi3 is offline
post #10 of 13 Old 12-08-2010
RichH's Avatar
If you have a decent grafix program you can 'enhance' the LAT/LON divisions by pasting in then carefully scaling 10:1 or 100:1, etc. 'grids' from the grfx program.
RichH is online now
What plotting tools? ditch General Discussion (sailing related) 6 07-23-2009 01:09 AM
Check My Plotting... 808state General Discussion (sailing related) 4 02-24-2004 02:35 PM
Check my Plotting... 808state Learning to Sail 4 02-06-2004 03:00 PM
Plotting Equipment Jim Sexton Learning to Sail Articles 0 08-18-2001 08:00 PM
Plotting Equipment Jim Sexton Gear and Maintenance Articles 0 08-18-2001 08:00 PM
