Sinking - Page 3 - SailNet Community
post #21 of 23 Old 04-10-2011 Thread Starter
davidpm's Avatar
The idea of a Pan Pan sounds good in principle sort of like a stop loss order on a stock. In practice I got the impression from past conversations that a Pan Pan reporting taking on water is treated the same as a Mayday.
Any coast guard people on-line that know what the CG protocol is for handling calls.
davidpm is offline
post #22 of 23 Old 04-10-2011
Originally Posted by dnf777 View Post
Great thread!
I like Omatako's plan of action. I would add that as skipper, you should assign duties, so many of the above tasks can be carried out simultaneously, saving precious time. I'm no longer surprised during situations (sailing and otherwise) that several people stand around doing the same thing, or all watching and give advice to the one person acting!
This question really reinforces the importance of situational awareness. When flying, if not actively engaged in another task, I'm constantly looking for where I could land if an engine were to fail, and always maintaining an awareness of my position, so if need be, I could give an immediate, accurate position. Its become so routine, its not a worrisome or energy consuming task. Its almost my way of relaxing.
On most of the boats I've sailed offshore aboard we discuss emergency management plans. Everyone is assigned duties to perform depending on the crisis. And if it's a race boat w/ lots of crew we try to always have a backup person.
For example: On a delivery if there is water in the boat everyone OFF WATCH is responsible for searching their sleeping area. Check the through-hulls/seacocks, watertanks, etc.And then move on to area's that haven't been searched yet.
IF an abandonship situation arises, there are duties assigned for grabbing the ditch bag, making Mayday calls on VHF/SSB/Sat phone, who is going to deploy the raft, etc. AND since there may be injuries.... backups to those duties.
I would disagree w/ DAVIDPM re: the PanPan to the CG. They are not going to come out just yet esp. if you let them know you are keeping up w/ or have found the source of the leak. They WILL appreciate knowing exactly where you are AND that if your Epirb goes off it is a legit emergency. That will save the time it takes them to call your contact person and verify that the boat is indeed offshore. Gets YOU rescued sooner and keeps them from a wild goose chase.
sailordave is offline
post #23 of 23 Old 04-10-2011
CapitainMike's Avatar
Originally Posted by JohnRPollard View Post
Joe,
The location of your bilge-pump through-hull isn't unusual, and normally shouldn't be an issue. There is supposed to be a loop of hose well above the waterline, with an anti-siphon break (also called a vented loop). This prevents water from siphoning back into the boat. Frequently, the symptoms you described above are caused by a vented loop that gets blocked up (often by dried salt crystals), allowing the creation of a siphon.
It's normally not recommended to add a check valve to your main bilge pump. Check valves are notoriously finicky and prone to jamming/clogging/failing. They also limit flow. Many people add them to a smaller "maintenance pump" to prevent drain-back and thereby keep their bilge nice and dry. But in that case, there should be a larger primary bilge pump that is not restricted by a check valve.
Sorry about the thread drift, David.
I agree with you its the same idea as an exhaust goose neck. Better to have the bilge outlet as high as possible and in the side not the stern. If you only have one pump I advise you to make it at least two pumps.
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
"Money won't buy you happiness but it will allow you to buy a yacht big enough to pull up along side it"
"Please God be kind to me your sea is so wide and my boat is so small"
CapitainMike is offline
Sinking of Rule 62 billyruffn General Discussion (sailing related) 641 10-21-2015 10:03 AM
Sinking RXBOT General Discussion (sailing related) 88 11-06-2008 03:14 PM
We're Sinking! jhulmer Seamanship & Navigation 32 11-05-2007 09:33 PM
Sinking Dink in tow Rogerdshoemaker General Discussion (sailing related) 1 10-30-2006 05:37 PM
Help! We're Sinking! Don Casey Seamanship Articles 0 03-21-2002 07:00 PM
