-   Seamanship & Navigation (http://www.sailnet.com/forums/seamanship-navigation/)
-   -   Local Noon (http://www.sailnet.com/forums/seamanship-navigation/73398-local-noon.html)
dnf777 04-05-2011 05:17 PM
Local Noon
Does anyone know where within a time zone does the local noon correspond with the clock? Is it half way across the zone? The eastern edge? Or are the lines totally arbitrary and it just falls "somewhere" in the zone?
AdamLein 04-05-2011 05:23 PM
As with so many questions, the answer is, "It depends."
The extra factor here is the Equation of Time, which is the difference between apparent solar time (what a sundial tells you) and mean solar time (what a sundial would tell you if the sun moved at a constant rate across the sky every day over the course of a year).
If the equation of time is zero, then local apparent solar time is equal to local standard zone time at the standard meridian for that zone. The prime meridian and every 15 degrees of longitude east and west of the prime meridian are standard meridians for the corresponding time zone.
So towards the end of December when the equation of time is zero, and we're not on daylight savings time (the navigator's bane), then at 120 W longitude (the standard meridian in my time zone), it will be local apparent noon when my clock says 12:00.
dnf777 04-05-2011 05:28 PM
I always set myself up for those "it depends" answers! ;)
Thanks, that makes sense. I forgot the earth's rotation and revolution aren't perfect circles.
centaursailor 04-05-2011 05:47 PM
In GMT, 0 degrees, its definitely on the meridian that passes through Greenwich Village, London.
Here in Dublin, 6,15" west, local noon occurs approximately 1225 GMT.
Safe sailing
AdamLein 04-06-2011 11:47 AM
Hilariously, the Greenwich meridian has moved several meters since the days of Flamsteed and the founding of the Royal Observatory, so if you go there and stand on the line they have marked, you will actually be in, iirc, a few arcseconds east. The new prime meridian is in the parking lot.
Some say it's a result of a more precise geoid. I subscribe to the "England is tipping over towards Ireland" theory.
Boasun 04-06-2011 02:38 PM
It is the center of the time zone with seven and a half degrees of Longitude on each side.
But you will need to check with the Nautical Almanac to determine true local noon for that time of the year.
LandLocked66c 04-06-2011 02:49 PM
So, this has to do with what exactly? Celestial navigation?
centaursailor 04-06-2011 03:37 PM
Been there in Greenwich and didn,t know it had moved::D
That last suggestion is well out of order:laugher
Safe sailing
Tea-Rex 04-06-2011 03:48 PM
It has to do with astronomy. Celestial Navigation makes use of it to determine Longitude.
Local Time for any point on the globe is the difference between greenwich time and the local longitude; 4 minutes of time for every degree or 4 seconds of time for every minute of angle. Add for East longitudes, subtract for West longitudes.
Determing Longitude with CN is reciprocal.
LandLocked66c 04-06-2011 03:50 PM
Slightly over my head, very interesting though. Carry on gents!
