Proper car location in track for Jib - Page 2 - SailNet Community
post #11 of 13 Old 06-13-2011
T37Chef's Avatar
I was thinking the leach line too? Remembering to ease it when the winds dies is the part I often forget
Shawn
T37Chef is offline
post #12 of 13 Old 06-14-2011
ASA and PSIA Instructor
To set your jib lead position correctly, sailing closehauled, head up:
- if the upper windward telltale lifts first, move the block forward,
- if the lower windward telltale lifts first, move the block aft.
In light air you may want to adjust the proper position a little forward for fullness, in heavy air, a little back to flatten the bottom of the sail.
If your leech is fluttering with the correct jib position in use, correct it with the leech line, if you cant then the jib needs to be worked over by a sailmaker.
sailingfool is offline
post #13 of 13 Old 06-17-2011
Dear all,
I stand corrected. Part 6 should read leech cord and FOOT cord. SVAuspicious raises a good point in that too often, especially in a heavy race, we all want to pack up quickly often resulting in things like the leech chord setup for heavy weather sailing and it may now only be blowing 15 knots. Every time you pull your sails up, let all the fine tuning devices off and start all over again.
heyross is offline
traveller track pcleary SailNet FAQ 4 10-10-2010 01:29 PM
CS 34 genoa car track padean CS Yachts 1 01-04-2010 11:32 AM
jib track on CD 25D craigw Gear & Maintenance 0 11-15-2009 08:53 PM
Available Track Cleats...? nicholas829 Gear & Maintenance 1 12-04-2008 11:59 AM
Re-bedding jib car track L124C Gear & Maintenance 12 11-25-2008 05:47 PM
