current theory - Page 3 - SailNet Community
post #21 of 25 Old 05-20-2011
Glad I found Sailnet
Bene505's Avatar
As I understand it, the only differences when going upstream (e.g. through Plum Gut against the tide on a rainy Sunday morning) are 1) a difference in apparant wind due to the boat's decelleration relative to the headwind we had, and 2) turbulence in the water.
Everything else is perception. It looks strange, as anyone who paddles up a slow moving river can attest. You feel "caught up" in the current when you turn away from due upstream, and it moves you quickly sideways relatively to the shore.
The shape of a plane circling in the sky (maintaining constant heading change) shows this very well by the shape over ground. If I can find that, I'll post it.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #22 of 25 Old 05-20-2011
Bene505's Avatar
This one is going downwind (like going down current on a boat), but it shows how the view is different.
This one shows going upwind (lower left picture), but it's a really small picture.
Note that the effect feels dramatic as the plane is really going fast downwind. Even turning broadside to the wind, you get pushed downwind. And after straightening out you end up back behind where you would have been otherwise.
As pilots we had to learn to make perfect circles over the ground on a windy day.
Regards,
Brad
Bene505 is offline
post #23 of 25 Old 05-21-2011
Boasun's Avatar
Originally Posted by AdamLein View Post
You're talking about the current that moves past the boat as a result of the boat's motion? Unless there's a very strong lateral force on the boat (like leeway), this current is always balanced on the two sides of the bow.
If you're talking about ground-relative current, as plenty of posters have already pointed out, you don't experience this current directly.
The subject is going into a strong current as stated in post #1. Currents from the side are compensated differently...
In post #14 I stated the facts as simply as possible. It doesn't really matter as to where you center of effort or propulsion is at... It is the fact that when you are stemming the tide or current (amounts to the same thing), when your bow falls off the course the bow up stream will have pressure on it and the bow section down stream will have much less pressure. THUS your bow will be pushed around if you are not applying correcting rudder. No need for higher math to explain it.
This is one of the reasons that a ship will take a wild sheer when going up river. The other reason is that the ship sniffed the bottom or the side of the channel. One or all of those reasons can, will and have caused many a ship, vessel and boat to run aground.
So pay strick attention to your steering.
But seeing how I've captained large supply vessels, large factory trawlers and sailed as mates on ships, under Post #1's conditions I do have an excellent Idea of what is happening...
But then there are people who will argue their point of view just for the fun of it... At least I hope that is their reason.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #24 of 25 Old 05-21-2011 Thread Starter
davidpm's Avatar
This makes sense if your boat is point directly up current.
Just a slight drift to one side or the other and this effect kicks in yes?
"It doesn't really matter as to where you center of effort or propulsion is at... It is the fact that when you are stemming the tide or current (amounts to the same thing), when your bow falls off the course the bow up stream will have pressure on it and the bow section down stream will have much less pressure. THUS your bow will be pushed around if you are not applying correcting rudder."
The point I'm making is that it is not, as far as I can tell, an illusion due to watching the shore.
Next time I'll through a blanket over my head and the pedestal so I can only see the compass. I'm pretty sure I'll still be able to tell by the feel alone that I'm fighting the current.
Do you agree. It is easy enough to test.
davidpm is offline
post #25 of 25 Old 05-21-2011
This appears to be one of those "Well it works in practice but does it work in therory?" Situations. I think the issue here is the preception of a more tender helm. The boat may be turning at a rate consistent with its speed thru the water but since by your visual refernces to land you're going more slowly when heading into the current the perception is that you're turning more quickly for the speed. According to this theory then your boat's turning should appear to be more sluggish when heading downstream.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
Theory on cause of Fiberglass Hull Blisters travistowle Gear & Maintenance 119 10-31-2011 08:59 AM
Sailing & boating theory Asiic3 General Discussion (sailing related) 0 10-11-2009 04:54 AM
New Theory on Seasickness LarryandSusanMacDonald General Discussion (sailing related) 15 04-03-2009 02:39 PM
More battery theory questions hertfordnc Gear & Maintenance 1 04-22-2008 08:47 AM
