Single Handing Made Easy - What Are Your Techniques? - Page 7 - SailNet Community
 3Likes
post #61 of 69 Old 04-02-2012
Remember you're a womble
PaulinVictoria's Avatar
Re: Single Handing Made Easy - What Are Your Techniques?
I was sailing this last friday and winds were 25 knots gusts to over 30. I had a inexperienced crew on board so I decided to just use the furled jib brought out about 1/3 way or less. With this sail I could only sail about 60 or 70 degrees off ture wind direction. I was being pushed off the wind by 5 foot seas coming from the direction of the wind, but I was hoping to make better windward direction than this. Would you say this is normal for mast head sloop?
Yes, a jib that is furled that much is going to be an ugly thing and won't point. Let a little more out and you'll have more power to punch through the waves and it will point better. Did you just have the furled jib? No main at all?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #62 of 69 Old 04-02-2012
casey1999's Avatar
Yes just a furled jib with no main. At for a time the winds were 30 with gust to 35 knots. I really did not want to unfurl jib further (and when it was most windy, I reefed jib and only had about a 1/4 out) due to the loading on the rig. I wanted to put up the main to give some better sail balance, but with the winds as strong as they were (and predicted to get even stronger), we sailed for a while then headed into the dock.
With just a furling jib what would be the answer if caught in strong winds such as this?
casey1999 is offline
post #63 of 69 Old 04-02-2012
Not much you can do really aside from sail off the wind more than normal.
Orange Crush
1974 C&C27 MkII
post #64 of 69 Old 04-02-2012
Round up behind an island ,drop the pick and stay a day or two.
Capt Len is online now
post #65 of 69 Old 04-02-2012
SERIOUS SAILOR
JoeDiver's Avatar
Originally Posted by casey1999 View Post
I was sailing this last friday and winds were 25 knots gusts to over 30. I had a inexperienced crew on board so I decided to just use the furled jib brought out about 1/3 way or less. With this sail I could only sail about 60 or 70 degrees off ture wind direction. I was being pushed off the wind by 5 foot seas coming from the direction of the wind, but I was hoping to make better windward direction than this. Would you say this is normal for mast head sloop? With the main and jib I can sail about 40 degress or sometimes closer to true wind directioin.
Those conditions would overpower me and I wouldn't be out in them. Remember, I have a Catalina 25....I need to reef the main once we're steady above 20....at 25/30g I'd need a fully reef'd main and a storm jib, like a 75 or smaller. Combine that with 5' seas....yeah, no. Too much for me by myself in such a small boat. Now, if I was in a big nice 36-38 footer.....
1982 Catalina 25 #2897
FK/SR/Traditional
Eagle Mountain Lake, Texas
JoeDiver is offline
post #66 of 69 Old 04-02-2012
TQA
Bombay Explorer 44
TQA's Avatar
Well I sail a 44 foot cutter singlehanded a lot of the time. Roller furling headsail, hanked on staysail and the main is slab reefed. I have a Mack sails stack pack dutchmen style set up on the main. All halyards are on the mast. When I first got the boat I played around with it and found it would tack OK with just the main.
So if in a situation where I am engineless and need to put the boat somewhere under sail. The genoa would get furled, and I would then drop the staysail and tie it up. I would then work it up to where I want it to be having centralised the traveller so the main is self tacking. Right spot, head to wind the anchor goes down, I might back wind the main to back down on the anchor. I then would release the mainsail halyard and the main rattles down into the mack pack in seconds with a little assistance.
I had to do this for real once when the pulley fell of the raw water pump. I did have the comfort of knowing I could run the engine at low rpm for maybe 5 mins but it was not necessary.
I have also picked up a mooring under sail but two up. I reckon I could do it single handed if needs be.
Marinas and tight docks = no way would I try that, I would anchor off and get a tow in. Too expensive if you get it wrong.
TQA is online now
post #67 of 69 Old 04-03-2012
Barquito
Barquito's Avatar
If you have a furling genoa, and only one reefing point in the main, the only choice may be to drop sail and motor. My most comfortable heavy weather set-up on my Catalina 22 was to reef the main (I only had one reef) and leave a little genoa unrolled. The small bit of genoa didn't help with drive, but kept the helm more balanced. If winds picked up more, I would just drop them and motor.
Barquito is online now
post #68 of 69 Old 04-16-2012
Senior in age only!!!
centaursailor's Avatar
My Centaur can hove to nicley with just a bit of the head sail furled out.
In heavy weather I reduce both sails progresivly, have only a single reef main but it also rolls away on the boom but not a great shape so anything much over 20knt and its the iron main and a quick dash for the nearest harbour.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #69 of 69 Old 04-30-2012
casey1999's Avatar
FYI, the other day was messing around with the boat. Had 20 to 25 knt winds and a rare very flat sea. With just the furling jib I could actually point very well. So conclusion is rough seas with just a jib, the boat will not point well because the wave action keeps pushing the bow off, just as you suggested. To lower the main I just back winded the jib (and remained hove to while I lowered and secured the main). The boat hoved to well with just the back winded partially reefed jib.
Single handing Irwin32 Seamanship & Navigation 140 06-01-2011 02:26 PM
Single handing skills cb32863 Learning to Sail 23 07-06-2010 10:39 AM
First single-handing Livia herSailNet 18 06-25-2009 09:44 AM
I am a single handing GOD! jbarros General Discussion (sailing related) 24 07-01-2008 10:06 AM
single handing foredeckman Cruising & Liveaboard Forum 0 01-18-2003 07:38 AM
