Bow in or stern in at the dock? - Page 2 - SailNet Community
post #11 of 33 Old 06-28-2011
JordanH's Avatar
My Contessa has a wind vane hung off the transom, a BBQ on the pushpit, and a transom/keel hung rudder; All of which make it advisable to dock bow-to.
However, there's another reason to go bow in; Not all boats back up predictably. I've only had my boat a very short while but I have yet to figure out her ways. She will turn, eventually, in the direction I want as I reverse but that happens in her time, not mine. Therefore, backing into a tight spot would be very difficult.
Other boats on which I sail have razor sharp handling in reverse and we back into the slip each night on race night.
The point being, outside of preference there is the physical ability of the boat design to manoeuvre in reverse.
JordanH is offline
post #12 of 33 Old 06-28-2011
The most female moderator
Donna_F's Avatar
Dock
If the shouts and expletives coming from the Island Packet skippers on the other side of our dock are any indication, those boats are hard to back in to a slip. A few owners did tell us that it's difficult for them and recently we and our neighbors watched an IP charter boat return and it was excruciating. They were determined to slam into every exposed bit of wood in the slip, then they gunned it forward and did it again. We've had our share of docking challenges but we do know how to use the throttle to move the boat not redesign the slip at full speed.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #13 of 33 Old 06-28-2011
jackdale's Avatar
Full keel boats are designed to track in a nice straight line. You need additional speed to get steerageway. Reversing is even more difficult when there is a 2:1 reduction in the transmission.
jackdale is offline
post #14 of 33 Old 06-28-2011
Mermaid Hunter
SVAuspicious's Avatar
Partial finger so getting on and off is easier stern-to
Loading the boat is easier stern-to
Shorter power cord stern-to
Works for me.
SVAuspicious is offline
post #15 of 33 Old 06-28-2011
turbulicity's Avatar
Can you expand on this point a little? Thanks.
1978 Gulfstar 50'
Clark Sailing Dinghy 10'
turbulicity is offline
post #16 of 33 Old 06-28-2011
jackdale's Avatar
Many transmissions have an approx. 2:1 reduction in reverse. That the prop rotates at half the speed per rpm in reverse as it does in forward.
jackdale is offline
post #17 of 33 Old 06-28-2011
Re Backing in
Those that back in usually do it for the convenience. Depending on how much water you have at your dock also has a bearing. Neighbor backed her new H36 into her slip for the first year. Loved the ease of loading and unloading. On her haul out the following spring she was dismayed to find that mud/slime had rubbed all the ablative bottom paint off the bottom half of her rudder and she had a nice barnacle farm growing. Thankfully we have a soft bottom so physical damage was done.
Cptken is offline
post #18 of 33 Old 06-28-2011
One of None
deniseO30's Avatar
privacy with bow in is worth the little extra effort when loading or off loading. but to do a 180 and bring her bow in after the loading is done is also an option!
My last project!
deniseO30 is offline
post #19 of 33 Old 06-28-2011
Bow in for relative privacy, stern in for rudder brushing and transom waxing
puddinlegs is offline
post #20 of 33 Old 06-28-2011
We dock bow in in our current slip, it just works better for the angles and the neighbouring boat. Backing out is OK - we are tied to starboard, walk to port (minimally) so back out to port, stop and head down the fairway forward. The privacy is another issue.
However we've always owned boats that back well, and if in a tricky or new situation we traditionally would back in (esp when we had a folding prop) so we had reliable 'brakes'. Also the boat actually controlled just fine in reverse. I've seen other designs that would totally preclude that approach.
Now that we have a Max prop we've got good brakes whichever way we go in.. so it's mainly a decision based on the particular docking situation if we're away on a cruise. Whatever works is fine for us.
Otherwise puddin's rules are as good as any!
Faster is offline
Jackline: to stern or not to stern dreuge Gear & Maintenance 10 12-24-2009 12:23 PM
anchoring bow and stern mugsy General Discussion (sailing related) 7 01-15-2008 10:28 AM
Stern docking nthompson General Discussion (sailing related) 8 08-04-2004 12:19 AM
Bow or Stern? mattyc Learning to Sail 6 05-14-2002 10:25 PM
Stern Anchors Mark Matthews Cruising Articles 0 08-14-2000 08:00 PM
