Wouldn't heave to in 25 knots of wind. - Page 2 - SailNet Community
 2Likes
post #11 of 41 Old 08-11-2011
Tartan 27' owner
CalebD's Avatar
Hey MarkSF
Originally Posted by MarkSF View Post
It's a Bristol 31.1.
Is this your boat? BRISTOL 31.1 sailboat on sailboatdata.com
If so why not at least put a link to your boat in your signature or put your boat make/model on your profile here. It would save dorks like me always asking you which boat you have. Just a suggestion and not a put down in any way.
Looking at the shape of your hull (if the diagram in my link is correct) you need very little jib to heave to and balance the main. If you have a furler you should be able to dial it in to what works.
I say this because I have a more full keeled boat and we can heave to with nearly a full jib usually. Your hull, while not a fin keel is not that far off and should turn pretty sprightly unlike my boat which takes some time to tack. To heave to your boat you need much more main then genoa up and you will find the balance it takes. In the SF Bay winds you get you may even need to reef the main and furl in the jib. You will figure it out but you've got to practice this in various wind strengths to really know what to do.
Sometimes just the main alone is enough to fore reach on. For more on forereaching go to: FAQs
This couple has sailed
way more then me.
Everybody has one:
CalebD is offline
post #12 of 41 Old 08-11-2011 Thread Starter
Caleb, yes that's the boat.
Yes, I would call it a modified fin keel. The jib is also very large compared to the main.
I've just got a brand new 100% jib, to replace the 150%. The problem with the 150 was that, when reefed to 100% or less, the shape wasn't great. In fact, it was old, so the shape wasn't great ever! So this may have contributed to the behaviour.
Anyway this weekend I'll try heaving to with the new jib, if that doesn't work will try furling it even smaller first.
MarkSF is offline
post #13 of 41 Old 08-11-2011
In reality, you aren't really going to heave to with a 150% genoa in any boat. For your boat, the 100% may or may not work. I'd guess the latter. With a storm jib in a big breeze, then you might be good to go. At that point, the storm jib isn't going to be pressed against shrouds, spreaders, etc... and self destruct.
puddinlegs is offline
post #14 of 41 Old 08-11-2011
Mark,
I think for your purpose..of taking in a reef, the goal is to take pressure off the main, so that you can ease the halyard and not have to fight the sail down. So, finding the right balance of rudder and jib is the key imo. If you have to harden up the mainsheet too much to hold your position, that kind of defeats the purpose. So in 25 knots, probaby a small jib would be enough. I have not sailed in SF Bay, but I understand the currents run strong. This is going to add an additional factor to your rudder positioning, depending on the strength and direction of the current vs the wind, you just have to play with it.
I don't know how the 31.1 behaves. I owned a 29 for many years. It tended to take a reef pretty early. I would have probably had 2 reefs by 25 knots. From what I read here about the SF Bay afternoon winds and have seen, I would probably have to leave the dock with at least one reef in 90 % of the time. Are the winds ever lite out there?
It seems like 15 to 25 is the norm.
tempest is offline
post #15 of 41 Old 08-11-2011
MarkSF,
The key to successfully heaving-to is to have the jib aback. To do this, sail on a close reach or a beat on one tack, then tack the boat thru the wind but don't touch the jib sheet. Leave the helm down, i.e., with the rudder turned away from the now windward side.
The boat will heel over quite a bit as the jib backs, but it will settle down quickly and begin a gentle forereaching and sliding off the wind, leaving a slick to windward.
This works well with most boats in most waters, including on SF Bay (I used to teach sailing in Sausalito).
You may have to ease the main a bit and with practice you'll see how your boat heaves-to best in varying conditions.
Again, the key is leaving the jib aback, so that it blankets the luff of the main.
Then, when you're ready to go, just release the jib sheet and trim on the other side.
Good luck this weekend.
Bill
btrayfors is offline
post #16 of 41 Old 08-11-2011
Bill, Rudder goes to windward...the backed jib pushes the bow to leeward..the rudder to windward counteracts.
tempest is offline
post #17 of 41 Old 08-11-2011
I have a heavy displacement modified full keel boat(Tayanna 37) and have difficulity getting it to point more into the wind when hove to. In fact most of the time I'm almost 90 degrees to the wind which is not much better than lying ahull. The Tayanna is cutter rigged and dousing the self tacking staysail has little effect on the position relative to the wind. The yankee has a high cut clew and while it's not a large sail it's probably over powering the effect of the main and rudder which are both trying to turn the boat into the wind. I'm going to try and see how well the boat heaves to under main along and wonder if anyone else out there has had good results under main alone with rudder locked hard turning the boat to windward?
lancelot9898 is offline
post #18 of 41 Old 08-11-2011
Lancelot, Perry had commented that the Tayana was a difficult boat to balance.. citing the mast being pretty far aft and the rake...usually the complaint was weather helm..
His solution was to suggest taking the rake out of the mast....How does that match up to your experience?
Have you tried staysail..and no yankee?
tempest is offline
post #19 of 41 Old 08-11-2011
Chastened
Ajax_MD's Avatar
Mark, I'm not seeing where you addressed this question: When you attempted to heave to, did you keep the tiller/wheel turned towards the boom?
If so, then the others are probably right that about adjusting your main trim to balance things out.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #20 of 41 Old 08-11-2011
Since the staysail is on a club boom it's not easy to back wind. My mast has no rake to it and it does not suffer from excessive weather helm. In fact I'm able to adjust the sails such that I can leave the helm on a close reach and the boat will stay on course if the wind remains constant.
Video, sailing in 35 knots wind! TeamICE General Discussion (sailing related) 20 07-20-2009 04:25 PM
Heave-To J-22 with no jib Starbuck1962 Seamanship & Navigation 14 09-25-2007 11:14 PM
At sea. Volvo Ocean Race: 35 knots of wind and movistar charges on more under water than above @ BYM Sailing News NewsReader News Feeds 0 04-15-2006 03:16 AM
UK. Raymarine Warsash Spring Series: 8 knots to zero wind dealt harsh blow to favourites @ BYM Sailing News NewsReader News Feeds 0 04-10-2006 04:15 PM
Heave to? KAYAKDAN Learning to Sail 6 03-14-2006 07:44 PM
