Raising the sails without the motor - Page 2 - SailNet Community
 2Likes
post #11 of 25 Old 09-23-2011
jackdale's Avatar
Originally Posted by PBzeer View Post
I'll second pulling your lazy jacks forward. I do it prior to getting under way, then re-set them as soon as practical.
Just curious - why would you want the lazy jacks in place as soon as a possible? I leave them at the mast until I lower the sail.
jackdale is offline
post #12 of 25 Old 09-23-2011
AdamLein's Avatar
Originally Posted by jackdale View Post
Sailing off a dock while being blown on is virtually impossible.
Isn't that what warps are for?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 25 Old 09-23-2011
chef2sail's Avatar
Jackdale is right on...I also keep the jacks forward for two reason...we have four full battons a I dont them snagging and with the jacks up they will rub and chafe the main.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #14 of 25 Old 09-23-2011
heave-to works good for me to thak sails down, and i expect it will work just as good for putting them up if you start with the jib.
luck66 is offline
post #15 of 25 Old 09-23-2011 Thread Starter
davidpm's Avatar
Would someone who has lazy-jacks that move forward post pictures. The ones I've seen have been fixed and I would like to see how they are setup.
Thanks.
davidpm is offline
post #16 of 25 Old 09-23-2011
jackdale's Avatar
Thanks.
The lazy jacks are attached to cleats on either side of the mast.
jackdale is offline
post #17 of 25 Old 09-23-2011
HANUMAN
RobGallagher's Avatar
C&C 30 MK1 w/ attached lazyjacks
I'm in a mooring field with lots of current that can affect how I come off/get on my mooring. Sometimes motoring is simply a safer approach.
Raise the main
Drop the mooring
sail off the mooring till I get a bit of speed
Unfurl the jib and trim... weeeeee!
Motor off the mooring
Unfurl the jib
Shut down the engine
Come as high as possible (pinch)
Raise the main... woooohoooo!
Head up as high as possible (pinch)
Drop the main, tidy up
furl the jib
start the engine
Furl the jib before heading to the mooring
Sail to the mooring on the main
Grab the mooring, get it over a cleat
Drop the main
Open beer/Gosslings
tidy up
(Having the jib unfurled and trimming it as much as possible allows the main to come/down easily)
RobGallagher is offline
post #18 of 25 Old 09-23-2011
jackdale's Avatar
Rob
You should be able to raise and lower the main while on the ball. Just do not harden the sheet.
jackdale is offline
post #19 of 25 Old 09-24-2011 Thread Starter
davidpm's Avatar
Are there cleats on the boom or special attachments?
Do they bang around a lot under sail?
Wait I looked closer and it looks like they remain attached to the boom but if that is the case is some portion of them stretchy or is there a block with extra line somehow?
OK I looked again.
You have a standard lazyjack setup with permanent attachment to the boom the very top line instead of being terminated 1/3rd from the top of the mast has a block at that point so the tail end can come down the mast and terminate in a cleat reachable from deck.
Did I get that right?
davidpm is offline
post #20 of 25 Old 09-24-2011 Thread Starter
davidpm's Avatar
Rob
Yes I did it this way all summer.
davidpm is offline
mast raising C27 MikeGuyver Catalina 4 06-12-2013 11:10 AM
Raising Waterline Livia Gear & Maintenance 6 01-21-2010 06:40 PM
Raising mast on T 27 drcov Tartan 4 02-15-2009 07:39 AM
T27-2 boom raising mtande Tartan 1 01-02-2007 06:33 PM
Raising the boom claudialuso Gear & Maintenance 8 04-18-2006 09:44 AM
