Mooring buoy bumps in the night - Page 2 - SailNet Community
post #11 of 22 Old 10-02-2011
imagine2frolic's Avatar
Gee on a cat I simply snug in the bridle....hehehehehehe.....i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #12 of 22 Old 10-02-2011
That's not fair!
Faster is offline
post #13 of 22 Old 10-03-2011
You could use extra fenders or a larger swimming noodle and tie them together around the mooring bouy to stop the banging.
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #14 of 22 Old 10-03-2011
Barquito
Barquito's Avatar
Is there anything wrong with mooring lines attached to the stern? It seems to have worked.
Barquito is online now
post #15 of 22 Old 10-03-2011
AdamLein's Avatar
Nothing, unless your mooring field is prone to large breaking waves :P In fact the boat will probably be more stable when tied from the stern.
I have anchored from the stern before and found that the noise of even very small waves lapping against the hull and transom to be a bit.... surprising. I didn't try to sleep through it.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #16 of 22 Old 10-03-2011
That's not fair!
There's got to be some advantantages for not going to windward.......i2f
post #17 of 22 Old 10-13-2011
Originally Posted by baboon View Post
As noted above this is an issue in the PNW given alternating wind and currents. I use a length of shock cord to keep the buoy away from the hull when things are calm. As wind or current picks up the cord stretches, and the load is taken up by the proper mooring line. This only works if you have a decent overhange and/or a pulpit.
http://www.sailnet.com/forums/attach...1&d=1317578143
Hi
I tried this [commercial link deleted - tdw] after the bow and anchor ring had a little get together. As usual, it was the bow that came off worse !
stuart 1965 is offline
post #18 of 22 Old 10-13-2011
fallard's Avatar
When all else fails, you might place a "necklace" of fenders (tied end-to-end) around the hard mooring buoy. You will still bump, but the noise will be substantially reduced. We've used this technique on more than one occasion.
fallard is offline
post #19 of 22 Old 10-14-2011
How about a pool noodle around the mooring ball? As the noodles are soft should be quiet and easy on hull surface.
RXBOT is offline
post #20 of 22 Old 11-03-2011
Huck
smallboatlover's Avatar
Around were i live in the basin this happens all the time. ive never seen any one do some thing about it. on some of the boats there marks on the hull bottom paint from the buoy wearing off on the hull of the boat. i did see some one putting pool floats around the buoy
16' mistral sailboat, And 27' coronado
smallboatlover is offline
Tags
bump , bumps , current , mooring , tide
Advice on putting my sailboat on a mooring buoy Huntertime Introduce Yourself 3 05-19-2011 04:25 PM
Where do you get your buoy info? zz4gta General Discussion (sailing related) 1 10-27-2008 11:49 AM
Blue Buoy Del Rey 50 walt5137 Boat Review and Purchase Forum 3 09-16-2008 07:03 PM
Bridle for Buoy Mooring maddata General Discussion (sailing related) 21 09-05-2008 06:29 PM
Protecting Re-Painted Topsides from Mooring Buoy wolfmt General Discussion (sailing related) 5 02-11-2008 11:14 AM
