Mooring buoy bumps in the night - Page 3 - SailNet Community
post #21 of 22 Old 11-06-2011
One sure doesn't want the copper paint scrubbing off the wooden hull by the mooring bouy. It's unsightly and the worms can get at you.I've used a mooring several times in the last 40 years or so but used the 12 ft bowsprit and a snatch block to the winch. I realize this isn't the answer for most of you but that's why gaffers rule.
Capt Len is offline
post #22 of 22 Old 11-19-2011
BostonSailor's Avatar
I know that cove well. Fun overnight spot, but those outer moorings can be tough because the strong ebb/flood current can run against wind direction and make the boat lay at funky angles. I've had some luck setting the rudder at different angles and have also hoisted the mooring ball and lashed it to the clear. I've found the northern side less pronounced. Fair winds!
BostonSailor is offline
Tags
bump , bumps , current , mooring , tide
Advice on putting my sailboat on a mooring buoy Huntertime Introduce Yourself 3 05-19-2011 04:25 PM
Where do you get your buoy info? zz4gta General Discussion (sailing related) 1 10-27-2008 11:49 AM
Blue Buoy Del Rey 50 walt5137 Boat Review and Purchase Forum 3 09-16-2008 07:03 PM
Bridle for Buoy Mooring maddata General Discussion (sailing related) 21 09-05-2008 06:29 PM
Protecting Re-Painted Topsides from Mooring Buoy wolfmt General Discussion (sailing related) 5 02-11-2008 11:14 AM
