Cross sheeting - SailNet Community
 2Likes
post #1 of 27 Old 10-24-2011 Thread Starter
davidpm's Avatar
Cross sheeting
All the old timers know this one but some new folks may not have thought of it.
Especially when sailing alone it can be handy to run a jib sheet across the cockpit from the leeward side to the weather side to cleat it off.
This way you can release the sheet from the windward side of the boat.
You can tighten the sheet by just yanking the center of the line directly towards the back of the boat then tightening up the slack. It's called sweating the line and is faster than getting out the winch handle.
Dinghy sailors do this all the time but it is working well here on a 25' Catalina.
davidpm is offline
post #2 of 27 Old 10-24-2011
djodenda's Avatar
That's a bit confusing to me.. If you take the turns around the windward winch, then you can use the winch handle and stay on the windward side....
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #3 of 27 Old 10-24-2011 Thread Starter
davidpm's Avatar
Of course you are right. but if you are in hurry or the handle is on the other side or you just don't feel like it it, or you lost the handle it is good to know that sweating a line like they did on the old ships before winches were common still works.
Just another simple old time trick that might come in handy.
davidpm is offline
post #4 of 27 Old 10-25-2011
One of None
deniseO30's Avatar
Cross sheeting is a very handy trick. I've done "just to see" how it works. Then it had me thinking.... If there was a single winch in the middle.... LOL
jimgo and Charlie B like this.
My last project!
deniseO30 is offline
post #5 of 27 Old 10-25-2011
captflood's Avatar
Greetings Earthlings The Sail Training vessel 68 ft only had one sheet winch in the cockpit centre and as with all sail training vessels if it is too heavey get more people on it the anchor was also lifted by hand other vessels in the fleet are the Sir Samual Withbreat, Falmath Packet, Francis Drake, Sir Thomas Sopwith,Tiakoo, and Grania all part of the Ocean Youth Club ( now the Ocean Youth Trust UK.) GO SAFE.
captflood is offline
post #6 of 27 Old 10-25-2011
Cross sheeting is very useful on lightweight boats upwind in a strong breeze, where the last thing you want to have to do is send someone from the weather rail down to the leeward winch to trim.
nolatom is offline
post #7 of 27 Old 10-25-2011
AdamLein's Avatar
I've tried it when singlehanding but so far I'm not convinced.
1) Trip hazard in the cockpit, right in front of the companionway? When singlehanding? Seriously?
2) I don't like sitting in one place for more than a couple of minutes at a time. Crossing the boat to trim the jib is a good excuse to move around and point my head the other direction. I need to peek under the jib to look for traffic more often than I need to trim the jib anyway.
3) I think on dinghies you really don't want to move around if you don't have to, because you are the ballast. But on bigger boats, moving around isn't as much of a big deal.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #8 of 27 Old 10-28-2011
saildork's Avatar
Good thread, David. I use cross sheeting frequently on my Catalina 22 when singlehanding. It just depends on the winds and how much moving around I care to do.
Sailing isn't a matter of life and death. It's much more important than that!
saildork is offline
post #9 of 27 Old 10-28-2011
Asleep at the wheel
jimgo's Avatar
Thanks for the picture; I was having trouble envisioning what everyone was describing.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #10 of 27 Old 10-30-2011
Boasun's Avatar
It also depends on the size of the boat... Some smaller ones do depend on your weight as ballast and cross sheeting may be necessary.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
any 30' cruisers with end boom sheeting since mid 90s tpm1950 Sailboat Design and Construction 29 12-26-2011 06:37 PM
Staysail sheeting for PSC37 johnbanfield Pacific Seacraft 15 08-10-2011 12:13 PM
jib sheeting angle choices.. Oysterbob General Discussion (sailing related) 4 07-15-2011 03:52 AM
Advantages of midboom sheeting? jbarros General Discussion (sailing related) 20 10-20-2009 10:15 PM
Mainsail sheeting arrangements Classic30 Sailboat Design and Construction 18 03-12-2008 07:17 PM
