How do you control engine throttle and gear - Page 2 - SailNet Community
post #11 of 34 Old 11-23-2011
Remember you're a womble
PaulinVictoria's Avatar
Think yourself lucky, I have to lean over the transom to reach the engine controls
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #12 of 34 Old 11-23-2011
I would travel into the slip with just enough speed that you can have it in idle reverse so when you need to stop you can just tap it with your foot. Works for me.
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #13 of 34 Old 11-23-2011
nickmerc's Avatar
One lever is nice. I have one for throttle and one for gear. I usually leave the throttle at idle and move in and out of forward/reverse as needed. I found that a slow, stable approach to the slip minimizes the need to "jockey the throttle".
nickmerc is offline
post #14 of 34 Old 11-23-2011
Barquito
Barquito's Avatar
This does not apply in all situations, but, when I want to pull up to my pin I throttle in reverese. While at the controls I watch over the side or transom at the water to see if I am still moving. I do have to take my eyes off the target for a few moments. Once stopped, I can pop it out of gear and go forward to grab the mooring.
Barquito is offline
post #15 of 34 Old 11-23-2011
HANUMAN
RobGallagher's Avatar
My previous boat had the throttle and selector down low. As others have pointed out, slow and steady wins the race.
I did consider fashioning a longer, removable, handle extension to attach to the fwd/rev lever just for docking.
Being on a mooring, most of my docking is coming up alongside.
Getting into or out of a slip is something I do once or twice a year. It can be pretty nerve racking. Acting like a prairie dog while docking just ads to the mess.
RobGallagher is offline
post #16 of 34 Old 11-23-2011 Thread Starter
casey1999's Avatar
This is exactly how I feel- a prairie dog- lol. I might try a piece of pvc pipe as an extension, even a 18 inch long piece would help a lot. I do like another poster said, look at the water to see how fast and relative motion of the boat, but that still is like driving a car by looking out a side window. I do go slow into the slip, but at times the wind will push me off and I back out and leave the slip and come around again. When this happens, the wind can blow the bow off and it would be nice to see what is happening while I am working engine controls. My slip is also basically a double slip with not even a piling between me and the boat next to me. So if the wind starts pushing the bow off, I can hit the boat next to me.
Thanks for all the advice.
casey1999 is offline
post #17 of 34 Old 11-23-2011
Slow is most certainly Pro
A technique I found useful (depending on the cockpit layout):
Stand with tiller between legs, steer with legs, this allows hands to be free to manipulate throttle and lines. Generally, manuvering into a slip requires small steering inputs, so the leg method works fine.
I also find it easier to "Prairie Dog" while standing up.
WDS123 is offline
post #18 of 34 Old 11-23-2011
HANUMAN
PVC pipe is just what I had in mind.
....and now "prairie dogging" has at least two meanings
post #19 of 34 Old 11-23-2011
I don't know how Schock expects you to stand and reach lever at same time. With that extension could be possible. Mine is even worse as mine is a T with a trigger that must. be engaged to shift between forward and reverse. I leave bumpers permanently on the dock side. If wind is bad coming in or leaving hang some off the boat on your slip mates side for a little extra peace of mind. No answer 4 me but that extension may work 4 u.
RXBOT is offline
post #20 of 34 Old 11-23-2011 Thread Starter
casey1999's Avatar
On my boat, I could not stand (steering with legs) and reach the engine levers- would still need to bend down and into the blind spot.
I also do the same with fenders, leave them tied to the dock and hang some extras. Have some on the boat on the side that may contact slip mate. So far have not had any issues with contacts, but had some close calls, getting better at docking, although want to be in full control of the boat and not to depend on the fenders. Leaving the dock I take the dock lines and pull to revese out to get some speed up and then jump on the boat and hit the reverse throttle and back out. Works well and in reverse, visability is not a problem as the transome is low.
A4 Clutch & Throttle Control Replacement jimmoser Atomic 4 1 09-18-2011 09:08 PM
Engine throttle control Greguk Boat Review and Purchase Forum 1 03-08-2010 01:15 PM
Help! I am going crazy with my Teleflex Throttle Control. What is t NewsReader Mass Bay Sailors 0 07-06-2006 08:15 AM
shift/throttle control firemanbob55 Gear & Maintenance 3 07-29-2005 06:29 PM
Throttle/Shift Control oldsaltydog Gear & Maintenance 2 01-02-2002 10:14 AM
