The challenge of experience - Page 4 - SailNet Community
 15Likes
post #31 of 39 Old 12-15-2011
jackdale's Avatar
Originally Posted by davidpm View Post
So I have a question for you. At 8 to 16 knots if the tide is going your way and you have a boat that can motor at 4 knots can you control the boat or do you have to wait for slack?
No, we wait for the slack. Dent Rapids can run 11 knots. Just south of the narrow section is an area called the Devil's Hole. It develops into a large whirlpool. Folks have told me that they have seen logs in there, which would turn it into a very big blender.
This link is a larger image- both show my route through.
http://i.pbase.com/o6/34/378634/1/13...p.Yucultas.jpg
I have gone with the current in a couple of situations that I know well.
jackdale is offline
post #32 of 39 Old 12-15-2011
Over Hill Sailing Club
smurphny's Avatar
Originally Posted by Bene505 View Post
David,
Our boat is really close to NYC now, in Port Washington. However, the thought of going through Hells Gate without experienced crew is a bit daunting. (That and making sure I get the tides right.)
When/if the time comes, I plan to call you and Caleb (and maybe put out a general call on SN and AS).
Regards,
Brad
I've been through the East River many times. It is no tremendous challenge and nothing to be afraid of. You do need to time it right so you're going with the tide. Other than that, the biggest worry is avoidance of water taxis and keeping your eyes open for flotsam/deadheads. There are plenty of places to wait for the tide on the Sound side, not so on the NYC side. Just behind the Statue of Liberty there is a small anchorage. If you're thinking of doing the Hudson: Coming down the Hudson the trip can be made from Nyack with the tide all the way to LIS. I've usually make it all the way from Haverstraw to Port Jeff in one day. From LIS going upriver, there is no way around bucking the tide going up unless you delay for about 3 hours in NY Harbor somewhere. I usually buck the tide to around the ?16th? St. Boat Basin, anchor there in the moorings (use a float), have a bite and wait for tide. Going out to Sandy Hook, you can ride the tide all the way and get the sails up. Sailing in and around NY Harbor is an iffy situation. The winds shift constantly because of the buildings. If there is wind, I always get sails up right after The E. River but they always require constant attention. In NY Harbor the current swells can be a factor as well as maneuvering in heavy traffic. With sails up, it complicates maneuvering. Having motor going and sails up definitely helps if you're bucking tide which runs 4+ knots just north of the Battery.
smurphny is offline
post #33 of 39 Old 12-15-2011
smurphny's Avatar
Something worth mentioning is that when you are sailing with the current, it is absolutely necessary to maintain headway through the water. If the wind is very light and your hull is going at the speed of the current, your rudder will be useless. I have had this happen a couple of times in some heavy current spots. It's disconcerting and very possibly dangerous when your rudder all of a sudden becomes nonfunctional and you cannot steer or keep the boat headed into waves.
smurphny is offline
post #34 of 39 Old 12-15-2011
Even more interesting is when the current suddenly increases big time. Until the boat catches up to the change, the rudder can actually works as in reverse.This will usually happen in a narrow channel between the rocks .ie ,Hidden basin,Roaring Hole, Surge N. Probably lots of other spots I haven"t yawed through yet. Hell with the waves, Rock are bad.
Capt Len is offline
post #35 of 39 Old 12-15-2011
I'm planning a trip to the canyon, 100 miles offshore. It will be the first time I'm really away from land. I plan to stay and fish for awhile and then sail back.
I'm also planning Montauk to Nantucket direct and return. Just need to find the time. So it's little increments for me.
Regards,
Brad
I've done the trip at least a dozens times over the years sport fishing. Problem I have with this is if I got to the canyon in a sailboat, I'd want to keep right on going
Bob
smurphny likes this.
misfits is offline
post #36 of 39 Old 12-15-2011
Bristol 45.5 - AiniA
Hell's Gate is not that bad
David,
Regards,
Brad
I have been through Hell's Gate several times and if you get the tides right it is one of the great anti-climaxes of our time. I went through when I screwed up the tide schedule and it still was not that bad - some overfalls and the like but not dangerous - slow as can be though. The joggers were passing us. I found the Cape Cod Canal to be much nastier and I think the two times I did that, I had the tides right.
Someone mentioned the name making it worst and I imagine this is part of it. One of the places we may stop next year is 'Hellville" in Mozambique. Named after a M. Hell and apparently not that bad.
More of a question than a comment - wasn't a major obstruction in Hell's Gate dynamited a number of years ago so that it is not nearly as nasty?
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #37 of 39 Old 12-15-2011
As a high school teacher I had the luxury of long summer vacations if i was not doing summer school of some sort. Experience came with going longer distances. I remember my first cruise in our Hughes 22. Went from Whitby to the Thousand Islands in Lake Ontario. Got to Belleville and found out that you needed a few dock lines that were longer than 15', so a lot of it is just increasing the challenge step by step.
For cruisers on Lake Ontario, after you have done the standard trips (across the lake 20 to 50 miles depending on route, going to the Thousand Islands); the next step is to leave the lake and head, typically, toward the North Channel in Georgian Bay - this was tougher because you had to deal with the Welland Canal, long trips on Erie and Huron, and river currents against you between Erie and Huron. The next step was to go into the ocean. We went to a Nonsuch regatta on Martha's Vineyard (Erie Canal with mast down, Hell's Gate tides!!). Next was offshore, in our club there was a bit of a tradition of going to Bermuda for a summer trip (2 weeks to Bermuda, 2 weeks in Bermuda and 2 weeks back). At each stage there was a new challenge and more things to learn. Most people on Lake Ontario never leave it and are happy to do the same things each summer, but other options - in logical steps exist if you want them. I guess I was always building experience but very importantly you are building confidence to tackle something new.
Now we are aiming to go from Australia around South Africa and there are new challenges and experiences including longer passages in the Indian and Atlantic Oceans and the nasty weather from SW Indian Ocean around the Cape of Good Hope. I feel OK about it because I have met other challenges in the past that seemed just as big a step as these ones.
Faster, St Anna and jackdale like this.
post #38 of 39 Old 12-18-2011
Swab
vega1860's Avatar
Originally Posted by erps View Post
My wife and I keep talking about heading out to Neah Bay one of these summers (instead of Desolation Sound which is our usual trip) and sailing a couple days towards Hawaii and then turning around and sailing back. We keep putting it off though, but I'd like for her to experience it before we put too much more money into the boat for our planned full time cruising retirement.
I don't think anyone would call us inexperienced but we don't claim to be experts either. We got our "Feet wet" so to speak by sailing straight out from Honolulu for a day, then sailing back before attempting inter-island voyages. We sailed across the Pacific in a square rigger to get an idea of what it would be like to be at sea for weeks at a time and Laura signed on to crew on a delivery of a schooner from San Diego to Kauai. Eventually, we sailed from Hawaii to Port Townsend and cruised in your neck of the woods for three and a half years before heading back to the islands. Our first attempt at leaving the strait was a little trying.
Don't show this video to your wife before you watch it yourself
This video is the follow up report in Neah Bay.
vega1860 is offline
post #39 of 39 Old 12-18-2011
aeventyr60's Avatar
One of our training cruises was out the Juan de Fuca Stratis and up to Barclay Sound. Fantastic trip, a bit rough on the way out but a big reward in cruising Barclay Sound. The next year we circumnavigated Vancouver Island and then headed off shore to San Francisco. Small steps on the way to Asia 12 years later. Go for it!
jackdale likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
ID the boat challenge. TQA General Discussion (sailing related) 9 08-19-2011 11:29 AM
Young Man, Big Challenge Jim H General Discussion (sailing related) 18 11-22-2008 08:06 AM
Frenchman With America's Cup Experience To Victory Challenge (Nautica) NewsReader News Feeds 0 09-19-2006 04:15 AM
The Global Challenge waltward General Discussion (sailing related) 2 10-06-2004 05:34 PM
