My Sails are Old and Baggy - Page 2 - SailNet Community
post #11 of 12 Old 01-04-2012
aeventyr60's Avatar
Fly your best sails. I don't have room for a bunch of old worn out sails. I take care of the ones I have and replace them when needed. As sailing is what I do, I see no reason to use worn out rags. In the big picture of boat expenses, new sails are not that expensive and the return on investment is priceless......
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #12 of 12 Old 01-09-2012
Barquito
Barquito's Avatar
Presumably if you ripped a sail in a storm, you would take it down and ride out the rest of the storm with a smaller sail, or motor. Then when things calm down, you could raise your baggy, back-up sail to keep moving. This will either get you to port, or give you time to repair the primary sail. There are probably a number of parts that are kept onboard as back-ups that are only ment to be used to limp back to port in the case of primary equipment failure.
Barquito is offline
Tags
safety , sail lifespan
New Sails EdHouston General Discussion (sailing related) 12 08-10-2013 03:25 PM
Racing Sails Vs. Cruising Sails??? NewportNewbie General Discussion (sailing related) 2 10-27-2011 03:25 PM
North Sails vs North Sails Direct DrB Gear & Maintenance 0 06-25-2009 10:00 PM
Used sails j34035 Gear & Maintenance 7 11-30-2007 08:17 PM
Teralani Sailing Adventures - Snorkel Sails, Sunset Sails and Whale Watched from Kaanapali Beach, Maui (About.com) NewsReader News Feeds 0 10-06-2006 12:15 PM
