SSB License - Page 2 - SailNet Community
 1Likes
post #11 of 34 Old 01-08-2012
How do you know it has a station license? Expire date should be on the certificate, which we keep in the nav table. If the prior owner got it, you will need to transfer it to your FCC account, which you will get when you apply for your restricted operators license. Caution: the FCC website is one of the worst and most confusing. Be patient.
If you have Digital Selective Calling on any radios aboard (and you should), the existing station license could have your boats MMSI number on it and it could be programmed into another radio. Otherwise, I suppose it would be possible to apply for a new one.
Jeanneau 54DS
Minnewaska is offline
post #12 of 34 Old 01-08-2012
The FCC doesn't transfer licenses. If the license was from the prior owner, that prior owner should have canceled the license when the boat was sold.
If you have an RRO, you may already have a Federal Registry Number (FRN). You can get this off you RRO, or you can look it up on the FCC website. You just need to get your password, and everything else is pretty straight forward. Just take your time, and make sure all the information is entered correctly.
windward54 is offline
post #13 of 34 Old 01-08-2012
JimMcGee's Avatar
I had a Ham license years ago. If I remember correctly technician was morse code only and general class allowed you to use voice.
Is morse code still a requirement for these licenses?
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #14 of 34 Old 01-08-2012
I can't recall specifically, but there is a bit more to the station license. You have to transfer an MMSI, which is on the station license if I recall correctly.
Jeanneau 54DS
post #15 of 34 Old 01-08-2012
As Windward54 said, the FCC doesn't transfer ship station licenses. If you don't have a station license issued to your boat upon your own application, then you will need to apply for one.
The MMSI number is issued by the FCC and will come along with the ship station license. THAT is the number which should be entered into any DSC transmitting equipment you have on board: VHF (including handhelds with DSC capability) and MF/HF SSB radios.
For Jim McGee: NO. There is no longer a code requirement.
The amateur radio Technician license allows you to operate mostly on the ham VHF bands, and voice only on a portion of the amateur 10-meter band and above (UHF). This latter is not very useful on a boat. That's why you need at least a General Class license to allow you to use voice transmission on authorized portions of the ham bands.
Bill
btrayfors is offline
post #16 of 34 Old 01-08-2012
Since the MMSI number can't be changed once programmed on a DSC radio, perhaps I'm recalling that you must transfer that number onto your new application rather than have one reissued?
Jeanneau 54DS
post #17 of 34 Old 01-08-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Minewaska: i know because I looked it up.
I emailed the PO to try and get the boat license cancelled.
I will use the site recommended by Bill to get new licenses. Thanks
To all for your help specially Bill.
brokesailor is offline
post #18 of 34 Old 01-08-2012
If you looked up its station license, then be sure to jot down the MMSI number if the FCC assigned one.
To confirm my sanity, I just signed onto my FCC account and began the process to apply for a new station license. After a half dozen questions, you are asked to either fill in the previously assigned MMSI number or request a new one. This must be the transfer concept I was recalling.
If the MMSI has already been entered into a DSC radio anywhere aboard, you will need to know that number when applying for a new station license. If you ask for a new one, you won't be able to match your radios, as the radios dont permit updates. (I do believe you can send them back to the manufacturer to be wiped clean, but who would want to bother.)
Jeanneau 54DS
post #19 of 34 Old 01-09-2012 Thread Starter
SV Skalliwag #141
I just installed a new VHF on the boat with remote mike. I did not know that the boat had a previous MMSI assigned so I got a new one and had it installed on the VHF. If the previous MMSI is in the SSB no biggie though I doubt it is.
post #20 of 34 Old 01-09-2012
You're right, this isn't the kind of biggie that sinks boats. However, when you get your station license for your boat, I'm fairly sure all installed radios must use the same MMSI. I'm not a pro on your SSB, but have a feeling it may not have DSC, so that could be moot.
I was more concerned that the prior owner had already programmed another radio, as you identified they did get a station license for your boat, and you would want to carry that forward.
As you applied for your own MMSI and haven't done the station license yet, can I assume you got a free one from BoatUS? If so, perhaps someone knows if you can use those on an FCC application. BoatUS MMSI numbers are valid in the US only, while those issued by the FCC are registered internationally. Again, no biggie, you just want to get your station license right.
If you have a US only MMSI, and are happy with it, you may be able to have your FCC station license issued without one. ( as long as the prior one is not programmed anywhere aboard )
Who's on first?....... Have fun.
Jeanneau 54DS
VHF License fees? saillife General Discussion (sailing related) 7 10-02-2010 06:56 PM
Fishing License Funsail Cruising & Liveaboard Forum 10 05-05-2010 08:55 AM
VHF license?? Crunch Cruising & Liveaboard Forum 29 08-21-2008 10:53 PM
CG License tx-sailor General Discussion (sailing related) 3 02-18-2003 01:39 PM
license value?? lizardie Learning to Sail 7 02-17-2003 01:42 PM
