Best routing information - Page 2 - SailNet Community
 7Likes
post #11 of 20 Old 01-10-2012
jackdale's Avatar
For passage planning I use the following as well.
NOAA weather fax
GRIB files
Both are available from Internet, but offshore weatherfax can be accessed via SSB > Modem > laptop and GRIB files can be accessed via email either SSB or Sat Phone. GRIB readers run the whole gamut of cost from free (UGRIB) to expensive (Expedition)
Get familiar with them at home online.
I use the North East Pacific weather fax
Northeast Pacific WX Briefing Package
For Internet based GRIB files I use UGRIB
www.ugrib.us
For email based GRIB files see Requesting grib files from Saildocs (2010-07-08)
I also have a slew of Android apps that I use for weather.
Also if you are going to cross the Gulf Stream, you may wish to use a routing service.
There are also weather routing services both free and for fee available.
jackdale is offline
post #12 of 20 Old 01-11-2012
Special Delivery
speciald's Avatar
Send a message via Skype™ to speciald
I use the MaxSea weather routing application. Grib files, polars of your boat, what the projected weather are are all used to produce a sailing route. The Gribs can be downloaded from their website enroute to update the routing underway. It has worked very well for me in passages to and from the Caribbean in the last 7 years. It is an expensive program, unfortunately, but works. It is also part of the Furuno Nav-net system.
speciald is offline
post #13 of 20 Old 01-11-2012
Bristol 45.5 - AiniA
Them, rather than it
Originally Posted by davidpm View Post
Well I've downloaded it not trying to figure out how to get it big enough to read.
Note that the pilot charts are monthly by ocean basin so you might need to dowload several. Also Cornell's book is a compilation of data from many sources including pilot charts. It is certainly the pre-eminent data source for planning passages. When we recently planned our trip from Oz to North America, it was a matter of we have to be here (for us South Africa) at a certain time and that means we have x weeks to get from here to there. There is a reason that people going to various parts of the world all go at pretty much the same time - and why another time might be quite dangerous.
A semi-politcal comment about Cornell's book. We buddy-boated with friends from Florida all the way to Oz, with several times when we went different places. We each started with a new Cornell. When I bought mine in Toronto I did not know, and the bookseller did not say, that there was a new edition out so I had one edition older. By the time we go to Brisbane, John's binding was falling apart and mine was still in almost new condition. The new edition is printed and bound in China, while my older one was done in the US. It is sad when we get crappy quality and people here lose jobs. I would bet the difference in price would be less than $5.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #14 of 20 Old 01-11-2012
casey1999's Avatar
Can someone explain how the Grib files are produced? I understand the files are all computer generated but what is the input? Do they use a satelite to get the input information? And what is the input information? If it is say Barometric pressure, how does a satelite measure barometric pressure?
casey1999 is offline
post #15 of 20 Old 01-11-2012
jackdale's Avatar
Here is the technical answer - http://www.wmo.int/pages/prog/www/WD...-binary-2.html
jackdale is offline
post #16 of 20 Old 02-02-2012
jimmalkin's Avatar
All above are perfectly appropriate direction to get your answers - I can only add buoyweather.com (sign up for a trial) is a great single source for forecasting that combines information from the usual multitude of weather prediction and ocean activity sources and puts them together allowing you to get lat/long specific forecasts for any given location.
White Rabbit
Vineyard Haven
jimmalkin is offline
post #17 of 20 Old 02-03-2012
Mermaid Hunter
SVAuspicious's Avatar
I use a software tool named Visual Passage Planner. VPP has the current pilot chart data by month. If you punch in the polars for your boat it will give quite reliable predicted passage duration estimates.
Jimmy Cornell has just announced a global package of updated pilot charts. See Noonsite for links.
SVAuspicious is offline
post #18 of 20 Old 02-06-2012
casey1999's Avatar
Originally Posted by jackdale View Post
Here is the technical answer - Guide to GRIB
I read through the link and still do not understand what data is being used to gernerate the grib chart. It seems that direct measurements of wind and waves is not the primary means to generate the chart. It seems satelites are used to measure maybe wind, waves, and barometric pressure. But how does a satelite measure these?
post #19 of 20 Old 02-06-2012
Mermaid Hunter
GRiBs are evil.
post #20 of 20 Old 02-06-2012
jackdale's Avatar
Originally Posted by SVAuspicious View Post
GRiBs are evil.
Because?
I sense that that they are more usual offshore as they do not seem to factor in land and sea breezes especially well. I also like the weatherfax, but will use all tools available to me before heading out into bluewater.
jackdale is offline
Texas to Venezuela Routing gypsysailing Cruising & Liveaboard Forum 12 01-22-2009 12:50 AM
Jib Sheet Routing Waugh Gear & Maintenance 14 05-20-2008 02:57 PM
VHF Antenna/coax routing goose327 Gear & Maintenance 15 03-01-2007 11:30 PM
coax routing question rb Gear & Maintenance 3 03-15-2006 06:51 PM
Routing Advice Sue & Larry Cruising Articles 0 07-13-2001 08:00 PM
