Conservation of angular momentum - Page 2 - SailNet Community
 5Likes
post #11 of 27 Old 03-01-2012
Bristol 45.5 - AiniA
One question
Originally Posted by davidpm View Post
That was exactly what was thinking.
I seriously doubt that hoisting an anchor to the top of the mast in a storm will help prevent a capsize.
Would it help if the anchor was a Rocna? (Could not resist)
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #12 of 27 Old 03-01-2012
pendulum effect
Conservation of angular momentum can be visualised in a playground by watching how kids slow themselves spinning by shifting their centre of mass outward on those spinning poles.
On a sailing vessel the principles are the same but you're not rotating continuously you're oscillating like a pendulum. Polar moment of inertia is the term used in vehicle dynamics but dynamic oscillation of sailing vessels is less well understood.
While you could in theory dynamically balance your vessel by changing its mass moment of inertia you are subject to somewhat random frequency and amplitude inputs in a real ocean making it a tail chasing exeecise. You already have sails with near infinite adjustment. When you've dropped all canvas you are left with the vessels design and configuration.
Leftbrainstuff is offline
post #13 of 27 Old 03-01-2012
RichH's Avatar
It all depends how far from the deck you raise your Rocna on a halyard!!!!! :-o
RichH is offline
post #14 of 27 Old 03-01-2012 Thread Starter
davidpm's Avatar
No one has addressed the specific condition.
Your at a protected anchorage. There is no danger of large continuous waves.
On occasion a single 1 foot roller comes in caused by the wake of of boat.
In this specific case would some extra weight in the rigging have the effect of damping the sloshing?
Any natural motion would have the probability of causing the boat to oscillate so weight aloft would only help for the first couple of seconds then would cause even worse oscillation.
But with a single wave caused by a boat wake, what do you think?
davidpm is offline
post #15 of 27 Old 03-01-2012
Don Radcliffe
I haven't done the math, but I can tell you that riding on a mooring with no mast is much worse than with a mast--the frequency of the roll is much higher, and so is the acceleration in response to a boat wake--enough to slide the coffee cups off the table. Seasickness is a strong function of frequency of oscillation, and it is one of the common complications of dismasting at sea.
I also think that the most common stability scenario is the dynamic response to being hit by a breaking wave from the side, where the taller and heavier masts give a distinct advantage. At one point I contemplated going to a carbon fiber mast, but the disadvantages at anchor and in storms made me decide to stick with the heavier aluminum.
donradclife is offline
post #16 of 27 Old 03-01-2012
In a real dynamic situation however the mass of the mast had a tendency to keep the boat from capsizing due to the conservation of angular momentum
No doubt you could calculate this using momentum, energy or inertia calculations. I find inertia calculations to be more intuitive.
If I look at my boat, I see the predominant inertias (around waterline) as:
Keel at 8200 lbs (3727 kg) , at about 1.5 m gives 8400 kgm^2 inertia
Mast 60 feet, 550 lb, 250 kg, at 10 m gives 25000 kgm^2 inertia
Fiberglass hull 11,000 lb or 5000 kg at 1 meter gives 5000 kgm^2
First I notice that the mast and rigging determine the predominant inertia, so yes the mast is the most important inertia that will resist acceleration. So if we have a fixed torque applied to this inertia, it will cause an angular acceleration much higher if the mast is missing.
The sum of inertias is 38400 kgm^2
Now lets put a 100 lb mass or 45 kg at the top of the 18 m mast. This gives an inertia of 45 * 18^2 = 14580 kgm^2
This added inertia is about 38%. So yes, this added inertia will also reduce the acceleration.
Just for kicks:
The derivative of my stability diagram is about 100,000 Nm/rad at zero. This is the effective spring rate of the water against the boat.
So the natual frequency of my boat is:
Sqrt(100000/38400) rad/s = 1.61 rad/s = 0.257 hz
so the natural period of my boat is about 4 seconds.
Without the mast, the natural frequency is:
Sqrt(100000/13400) = 2.73 rad/s = 0.434 hz or 2.3 second period
So if we just consider inertias, the angular acceleration will higher when the mast is missing. On the other hand, the angular displacement is the same with or without the mast because the frequency has changed.
However, the problem comes that we have neglected damping. When you reduce the inertia, the acceleration is higher, the velocity is higher, so the damping is higher. Since damping is proportional to angular velocity, the damping is going to be higher by about the ratios of natural frequencies: 0.434/0.257 = 1.7 times higher without the mast.
When we consider the higher damping and the higher frequency without the mast we find that the heeling angle goes down without the mast because the damping is higher.
Here is a simulink model that illustrates the effects.
Bene505 likes this.
BryceGTX is offline
post #17 of 27 Old 03-01-2012
Glad I found Sailnet
Bene505's Avatar
Originally Posted by Barquito View Post
So, say you are motoring in a seaway where the wave train (or a harmonic) is the same frequency as your boats roll rate. Would it reduce roll if you hoist some weight up the mast until the roll rate of the boat is different than the waves?
I think Bryce just answered that one extremely well. The answer (tongue in cheek) is to send a friend aloft. A 100 kg person at the top of Bryce's mast has this effect:
Originally Posted by BryceGTX View Post
With mast:
With 100kg buddy at the top, this adds an additional 100 * 18^2 = 32,400 kgm^2
Sqrt(100000/(38400+32400)) rad/s = 1.19 rad/s = 0.189 hz
so the new natural period is about 5.29 seconds.
But if you are motoring and your friend won't go aloft, you could change your angle to the waves, thereby changing their apparent frequency and preventing oscillation. It's David's anchoring scenerio that makes you want to hoist something aloft.
Good thread.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #18 of 27 Old 03-01-2012
So now we run the Simulation with the mast. We see the natural frequency period of about 4 seconds and we notice that the damping causes the rolling to die out after about 5 cycles.
We notice a peak angular displacement of about +-4 degrees. THis is with a 5 degree step forcing function.
BryceGTX is offline
post #19 of 27 Old 03-01-2012
Now we remove the mast inertia. We notice the natural frequency increases and so does the damping. The damping causes the rolling to die out after only about 3 cycles. And because the frequency is higher, the damping cause the angular displacement to be limited to 3 degrees.
BryceGTX is offline
post #20 of 27 Old 03-01-2012
Even though the heeling angle is reduced without the mast, you may be more sensitive to the accelerations. In that case, without the mast, the accelerations are about three times higher than with the mast.
And since these accelerations are such low frequency, the higher accelerations may actually be more uncomfortable. And since the heeling angle is only slightly reduced, but a higher frequency, we may also find this more uncomfortable.
BryceGTX is offline
Holding Tank Conservation methods? Gene T Gear & Maintenance 17 06-05-2010 09:32 AM
Refrigeration Conservation Cruisingdad Cruising & Liveaboard Forum 42 03-06-2009 10:37 AM
Momentum - and a lack thereof. tdw Gear & Maintenance 24 11-20-2007 07:31 PM
Support Conservation Research Expedition SheilaMarie Cruising & Liveaboard Forum 60 03-24-2007 03:28 PM
DeVos looks to regain his momentum (Detroit News) NewsReader News Feeds 0 09-28-2006 02:15 AM
