Dipping a Light - SailNet Community
 1Likes
post #1 of 12 Old 03-09-2012 Thread Starter
davidpm's Avatar
Dipping a Light
Just ran into a fun term and concept for navigation.
"Dipping a light".
I've experienced it a few times but never used it for navigation.
Might come in useful some day?
davidpm is offline
post #2 of 12 Old 03-09-2012
Re: Dipping a Light
I've played with it, to see how close I come to estimating my distance off. It's something to do, in the middle of a night watch. I think it's good practice.
tempest is offline
post #3 of 12 Old 03-09-2012 Thread Starter
davidpm's Avatar
Re: Dipping a Light
How close did you get
davidpm is offline
post #4 of 12 Old 03-10-2012
Re: Dipping a Light
Let me guess . If you are looking up at a light house you know to be 300' high, you are pretty close.
Capt Len is offline
post #5 of 12 Old 03-10-2012
flyingwelshman's Avatar
Re: Dipping a Light
Is this another term for establish distance off a known object?
I learned these formula:
If you are working in feet:
d=1.17 x √height of object(ft) + 1.17 x √height of eye(ft)
In metres:
d=2.1 x √height of object(m) + 2.1 x √height of eye(m)
(d = distance off in nautical miles)
You have to take tides into account where they apply.
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #6 of 12 Old 03-10-2012
Re: Dipping a Light
Yes, the formulas yield you the distance from each object to the visible horizon, added together they give you the distance from the Light. Take a bearing draw a line that distance and bearing and you should arrive at your EP. Take a look at your depth..see if it matches up to the chart. I've come pretty close when using it. You can also use tables that are already pre-calculated, just match up the two known heights in a box to see the total distance. Height of tide will make a slight difference..a pitching sea will have an effect.
tempest is offline
post #7 of 12 Old 03-10-2012
Re: Dipping a Light
1989 Hunter 30'
post #8 of 12 Old 03-11-2012
Re: Dipping a Light
Useful, especially when you are looking for a distant light, even the markers on bridge towers, and someone says "I see it. No, wait, I don't. No, I do. Wait, I don't."
Now you know they've dipped the light and a quick look-up gives you the range. Or you can put a pencil line on the chart with your compass, i.e. where you expect to dip the light, and when that happens you know "We are here. Ish."
hellosailor is offline
post #9 of 12 Old 03-31-2012
Lighthouses are indicated on a chart with the height of the centre of the light (in metres) above MWHS. Be mindful though that both the lighthouses below are 40m high, but the yacht on the right might be expecting to see a tall tower from the lighthouse on the left.
Shawnibrion is offline
post #10 of 12 Old 03-31-2012
CaptainForce's Avatar
Re: Dipping a Light
flyingwelshman, I like the convenience of the chart that you presented, but please help me with a simple clarification. By international standards of measurement I believe the symbol "M" designates meters; however, this can't be the case with this chart. I'm assuming the data within the body of the chart is miles. Is this correct or would these be Kilometers? Take care and joy, Aythya crew
CaptainForce is offline
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
LED Bow Light Bene505 Gear & Maintenance 20 02-07-2009 10:59 PM
bow light for H22 bome Gear & Maintenance 5 07-22-2007 08:56 PM
Extra green time for smooth sailing over new bridge: Extra green light time sought Extra green light time sought over (Asbury Park Press) NewsReader News Feeds 0 04-23-2006 05:15 AM
