Reasons for knowing TVMDCAW - SailNet Community
 14Likes
post #1 of 28 Old 05-02-2012 Thread Starter
davidpm's Avatar
I've been volunteered to give a short instructional presentation on a nautical topic. The topic selected is titled "Variation, deviation and compasses"
The subject is easy enough but can you think of any answer to the inevitable question of why.
If you hop on a boat today with 4 people you probably have at least 6 GPS's on board.
Yes the satellites could fall out of the sky half way through our 3 hour cruise or the military could block the signal but can you think of any more likely ways, knowledge of the subject could come in handy.
davidpm is offline
post #2 of 28 Old 05-02-2012
JimMcGee's Avatar
Re: Reasons for knowing TVMDCAW
Assuming no handhelds on board
  • Dead battery
  • Bad ground causes a loss of electronics
  • Lightning strike takes out chartplotter
  • Chartplotter screen craps out (it's a Raymarine C-series)
  • Space aliens (hey it could happen!)
Or if you have a handheld as a backup:
  • You have no AA batteries
  • The handheld uses up it's batteries
  • Batteries in the handheld are a crusty mess because it's been laying in the nav desk forever
sneuman and davidpm like this.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #3 of 28 Old 05-02-2012
GPS satellites do not have to fall out of the sky. They are occasionally shut down or down for maintenance. The system is supposed to keep enough up and running that you never know. Not always the case. In aircraft, there is integrity monitoring to determine whether there are sufficient signals to complete a course, not just receive your current position. They are also principally designed for military use and you can be certain they will jam them as they see fit for security purposes.
davidpm likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 28 Old 05-02-2012
wayina's Avatar
Send a message via Yahoo to wayina
Yep the answer is if you do any navigation exercise that requires an examination you have to know it,
davidpm likes this.
"No, it's not going to be fine. Change is never fine. They say it is, but it's not. "
wayina is offline
post #5 of 28 Old 05-02-2012
Isn't it at least interesting when you're telling them why you add Whiskey to True Virgins?
davidpm likes this.
nolatom is offline
post #6 of 28 Old 05-02-2012
RhodesSwiftsure's Avatar
Drawing out two compass bearings to provide a pilot fix is about as visceral as Cartesian geometry gets. Cartesian geometry is the practical wedge of the entire enlightenment. Being able to perform the required technical steps connects one with the renaissance thinkers who enabled the modern era.
That's a long way from buying an app.
davidpm likes this.
"The slower we moved, the more we seemed to see."
- LP
RhodesSwiftsure is offline
post #7 of 28 Old 05-02-2012
jackdale's Avatar
Know the basics before you get all technical.
Life and death - danger bearings.
There is a reason we still teach arithmatic in the digital age.
If there is a problem, you should be able to recognize it and fix it.
dacap06 and Minnewaska like this.
jackdale is offline
post #8 of 28 Old 05-03-2012
jackdale's Avatar
btw - when I teach that portion it is a whole evening. If you want the notes PM me with your email and I will send them.
jackdale is offline
post #9 of 28 Old 05-03-2012
Jack makes a critical point that applies to all electronic navigating. Like it or not, most electronic navigation systems can do better than a human. The humans job is to supervise very diligently and have the skills to take over if the electrons aren't flowing properly.
JimMcGee and davidpm like this.
Jeanneau 54DS
post #10 of 28 Old 05-03-2012 Thread Starter
davidpm's Avatar
Danger bearing is a great example of how this old school stuff can still be useful.
Thanks
davidpm is offline
20 years without knowing, So I thought I'd ask. dockbumdan Diesel 41 12-10-2011 07:51 PM
Reasons NOT to go Cruising vega1860 Cruising & Liveaboard Forum 98 08-20-2011 03:47 PM
Reasons to Date a Sailor SailChick20 General Discussion (sailing related) 12 02-20-2009 04:49 PM
