Advice Sought for minimalist coastal navigation - Page 3 - SailNet Community
 3Likes
post #21 of 23 Old 06-19-2012
Re: Advice Sought for minimalist coastal navigation
Originally Posted by hriehl1 View Post
Tempest... thanks, that appears to be my missing link and if I'd fired up the MapTech package before posting I'd have had my answer. Thanks again.
Henry, No problem. I've been meaning to test it myself, ever since garmin stopped supporting real time tracking in Mapsource, your post just gave me the incentive.
tempest is offline
post #22 of 23 Old 06-19-2012
Sailing out of Salem, you should be good doing this. Salem sound has a lot of shallow water but the buoy coverage is excellent and they don't tend to move around. The places where the buoys move a lot tend to be the ones on the North side of Cape Ann like Annisquam, Essex Bay, Ipswich and Newburyport.
klem is offline
post #23 of 23 Old 06-19-2012
Geoff54's Avatar
Originally Posted by GMC View Post
I use OpenCPN for setting waypoints and then free program called "EasyGPS" (also free) that dumps the waypoints onto my 76, so I don't have to punch them in. That used to be a killer. So, I sit at home or work, set my waypoints (you will use routes once you see what OpenCPN can do) and then hook my 76 to computer at home or work, send the waypoints over using EasyGPS and then walk out the door to go sailing with only my 76s. Very nice and all I need. No computer on board. No chartplotter, other than the basic route screen on the 76, following a black line with no map on it. No PC on board. Works great. See you out there.
Greg
EasyGPS is great and it also easy to enter waypoints directly into the EasyGPS screen if you are not using OpenCPN or similar. But do make sure you are using the same degrees/minutes settings on EasyGPS and Garmin. My Garmin defaulted to hddd mm.mmm (which I prefer) while EasyGPS defaulted to hddd mm ss.s
I entered hddd mm.mmm waypoints into hddd mm ss.s fields and, once I realized, I had to change the setting in EasyGPS and then enter them all again (couldn't find an easy way to convert). I'm glad I decided to check them against the chart before I set out.
Geoff54 is offline
Coastal Navigation Software??? tsingtao Gear & Maintenance 5 08-13-2007 03:13 PM
dinghy advice sought dinghyfan General Discussion (sailing related) 6 07-19-2007 10:13 PM
Intro and Advice Sought Tntonboard Cruising & Liveaboard Forum 30 03-23-2007 04:49 PM
C&C 24 Advice/Opinions Sought psterne Boat Review and Purchase Forum 2 01-30-2003 10:41 AM
NYC to Chesapeake Advice Sought halyardz Cruising & Liveaboard Forum 2 10-02-2002 11:56 AM
