Let's talk about anchors some more - Page 14 - SailNet Community
 29Likes
post #131 of 184 Old 08-04-2012
BrianFortress's Avatar
Re: Let's talk about anchors some more
Originally Posted by Mantus Anchors View Post
No disrespect to the Fortress Team, I keep a FX-37 on my boat for a rainy day
I think in looser bottoms it is a clear winner.
Greg
Thanks! And be sure to permanently install the Mud Palms, as they will improve the setting performance by lifting the back end of the anchor up so that the flukes will take a more aggressive angle into the sea bottom.
Best wishes for success with your product!
Sincerely,
Brian
BrianFortress is offline
post #132 of 184 Old 08-04-2012
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by BrianFortress View Post
I agree. E.S. "Mac" Maloney, 90+ years young and long time author of Chapman's, has used a CQR successfully for decades. Tom Neale, another noted boating author, has cruised and lived aboard since the late 70s, logging several thousand miles per year, and he has also used a CQR successfully during that time.
If I were to suggest to them that their CQR was a bad anchor because it performed poorly in a controlled anchor test with 5 or so pulls, then I suspect their response would be one of disbelief, and possibly even hysterical laughter.
I have heard similar accolades from Bruce owners as well.
Do the "new generation" anchors offer improved performance over the older models? I believe so, but those older models certainly have earned a loyal following over the years....even up to this day. I still see them mounted on the bows of many different types of boats by a vast majority at the shows.
I think Brian makes THE fundamental point. The availability of better anchors doesn't make older anchors less good. It simply gives those of us in the market for an anchor better performing alternatives.
I've spent a lot of nights hanging on a CQR or a Bruce and many many nights on a Delta. I'm much more comfortable now hanging on a Rocna. I'd be just as happy on a Spade or Raya. Although I haven't used one, I'd probably be just as content on a Mantus or Manson Supreme.
If I had a 1964-1/2 Ford Mustang I'd be content with the drum brakes. If I was buying a new vehicle I darn well would be sure to get four wheel disc brakes. CQR = drums; Rocna/Spade/Mantus/et al = disc brakes.
killarney_sailor likes this.
SVAuspicious is offline
post #133 of 184 Old 08-04-2012
Greg
Sincerely,
Brian
Now for those of you that remember the ego filled competitor bashing ways of Rocna, THIS is what buyers like to see.
Congrats to both of you.
Why are people happy to accept science which makes their life easier while rejecting science that makes their faith or beliefs more difficult?
cupper3 is offline
post #134 of 184 Old 08-04-2012
Your post brought up a painful memory. I did have a 1964-1/2 Ford Mustang convertible, my first car. After I wrecked it, I think I got $40 for it from a salvage yard. Today it would be worth....
I still have the original hub caps...
SVAuspicious likes this.
post #135 of 184 Old 08-04-2012
cupper3,
Thank you! I have to say, that whole debacle was very out of the norm for us anchor manufacturers. I have met and regularly talk with the guys from Manson, Rocna (new team), Spade, and Ultra at the boat shows, and there is nothing but respect between us, as it should be.
I am sure that Greg's and my paths will cross one day soon at a boat show and I look forward to meeting him as well.
post #136 of 184 Old 08-05-2012
Moody 46
I love reading peoples take on anchors. So important! I have spent a lot of time researching the different types and have had the luxury over the past 4 years to observe and test from the Great Lakes to the Med, Africa, Canaries,and the length of the E.Caribbean.
First, if you use a CQR for anything other than a paper wt dump it!! It is the most popular really bad anchor ever invented. Only good thing about it is how nicely it hangs on the bow roller.
If you tend to stay in one area you can go with an anchor good for that bottom type but otherwise a solid all around is a must. Wt. really is more about penetrating weed, grass, and firm bottoms. Holding has little to do with wt. For example the Spade aluminum has the same holding power as the steel.
Bottom line, go as big as you are comfortable with. If you have a windlass carry as much chain as practical for the boat. Go with something like a Spade, Mason Supreme, Rocna, etc for primary anchor. Deltas still good anchor as well, I have one as a secondary along with a fortress secondary.
Great sailing all
orthomartin is offline
post #137 of 184 Old 08-06-2012
Ok, I am going to try "disk" brakes vs. my old "drum" brakes. Just placed an order for a Mantus 35 lb. anchor....we'll see how it works out. I don't anchor out much, but the thought of anchor failing when I do is not good. I'm not abandoning the tried and true Bruce and Danforth types. I plan, initially, use the Mantus to supplement the others so that I more fully cover the range of bottoms I may encounter, and as a storm anchor. I debated getting a 45 lb. anchor, but at 73, I have to watch out for things that are too heavy. A few years earlier, I would have gone with the 45 lb. anchor just to be sure. I chose the Mantus because I can disassemble it and store it below. Fortress has this same capability, but I my case, I feel that I cover the range of bottoms more widely with this anchor given the anchors I already own.
NCC320 is offline
post #138 of 184 Old 08-06-2012
Mermaid Hunter
I've seen a couple of really nice mailbox stands made from CQRs. *grin*
post #139 of 184 Old 08-06-2012
I thought of this thread this weekend, when anchored in a full bed of grass at Cuttyhunk. I put the 75lb CQR down and knew it wasn't set. I would back against it, go to zero SOG and then it would jump and back to zero again, etc. I was clearly getting hung up in weeds and then ripping them free and repeating.
We had just arrived from a 4 hour passage in 100 foot of visibility and were a bit shot, so I dropped about 100 feet of 1/2" chain in 10 feet of water and took a break. I would go back and reset later. With only about 10 of wind, I wasn't moving, despite not being set properly. People started filling in around me and having equal trouble setting. All gave each other plenty of room, for obvious reasons.
About 5 hours later, I checked the Ipad Anchor Watch app, which tracks your swing trail and you can visibly see if you're dragging. We hadn't moved an inch. Not one inch. So, with winds forecast to drop even further over night, I just stayed put.
The following morning, we had swung about 20 degrees on an arch (just as forecast winds suggested) and never dragged.
Perhaps this wasn't my best form, but I'm certain this only worked, due to the shear weight of the gear sitting at the bottom and the low wind. Would you say that the anchor and chain weigh roughly 900lbs?
Bigger just may be better after all.
Capt.aaron likes this.
Jeanneau 54DS
Minnewaska is offline
post #140 of 184 Old 08-06-2012 Thread Starter
KNOT KNOWN
Capt.aaron's Avatar
BIG GOOD BIGGER BETTER. There a vareity of anchors to carry for a variety of bottoms, and I'm looking forward to checking out the Mantus, but all of them should be on the smart end of some big ass chain!
" Some are boat wise and some are other wise"
Capt.aaron is offline
Talk about blow... Cherp General Discussion (sailing related) 4 05-20-2012 08:43 AM
Somebody try to talk me out of this! BlackFlag Introduce Yourself 9 02-16-2012 08:43 PM
Talk me out of it richard1976 Boat Review and Purchase Forum 28 02-16-2012 03:22 PM
Just try and talk me out of it Sidetrack Boat Review and Purchase Forum 0 09-26-2006 09:46 PM
Talking the Talk Carol Cronin Racing Articles 0 05-13-2002 08:00 PM
