wind conditions and reefing - Page 3 - SailNet Community
 38Likes
post #21 of 55 Old 07-26-2012
casey1999's Avatar
Re: wind conditions and reefing
Originally Posted by AndreasNYC View Post
I think my question was not so much about my sailing skills but about technical specifications and how to interpret them.
I added it to my profile, but for the record
I have an ALOA (no H) 34 its from 1974.
I am more trying to figure out what to do when overall wind is below reefing speed but there are gusts that go above. There are of course ways I can adjust the rigging so less wind his the sails, or I can head up-wind in a gust to keep from getting blown over.
Do you think the boat would get blown over in a 30 knot gust? Or just heel some more?
Andreas
I have a 34 footer draws 6 feet with 5,000 lb lead in the fin keel. I put a reef in the main when the wind hits a constant 20 knots (with gust to 25). and reef the furler jib a little. At 30 knots I would have two reefs in the main and the jib in more. was sailing like this once when gust hit over 40 k and suddenly started to lay the boat down more than I liked- quickly released the main sheet and boat came back (a little scary when single handing). I would set the sails for the largest gust expected. I'd rather be going slow and in total control.
casey1999 is offline
post #22 of 55 Old 07-26-2012
captainrizzo's Avatar
The misnomer here is that a reef or two slows you down. In my experience, a properly reefed main with good sail shape will actually help you sail faster, all else equal. Excessive heeling is what slows you down.
-Riz
2005 Catalina 350 Grazia
"If you want to build a ship, don't herd people together to collect wood. Just teach them to long for the endless immensity of the sea"
Antoine de Saint
My Blog:
captainrizzo is offline
post #23 of 55 Old 07-26-2012
casey1999's Avatar
I think the problems come when say the wind varies from say 10 knots to say 35. I would reef for say a 30 knot wind and be able to handle the 35. But at 10 knot, I'm going to be going slow, and if I got a big sea, getting knocked around a lot with no power. It is a predicament.
post #24 of 55 Old 07-26-2012
Seriously? When is the last forecast you saw that was 10 kts, gusting to 35? The OP asked a question about being in 15-20 and being hit with a 30 kt gust without a reef. To your point...I wouldn't reef a sunfish in 10 kts even if you could reef a sunfish. Come on.
SVAuspicious and msmith10 like this.
-Riz
Antoine de Saint
My Blog:
post #25 of 55 Old 07-26-2012
casey1999's Avatar
Come out my way and I'll show you 10 knots gusting to 35. I do not generally pay much attention to forcast. I have heard forcast here calling for 15 knots and I'm sailing in 35 at the time.
What's the sunfish got to do with anything?
post #26 of 55 Old 07-26-2012
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
I'm surprised so few focused on heal instead of weather helm and rounding up in the gusts! In the skipjack I reef the main at 15 , at 20, I reef the jib, for gusts to thirty i want to be relaxed so probably would reef the main again. With that set up my tiller is easy and boat is up to hull speed. In the Morgan Id half reef (fishermans) an furl the genny to the mast. BUT my primary guide is helm pressure aka who is steering the boat and that is not atechnical calculation but a balance of boat sea and sky.
Cod
oysterman23 is offline
post #27 of 55 Old 07-26-2012
Cruise w/ your sails set for the gusts. Racers set their sails for the consistent wind and just deal w/ the gusts.
Singlehanding I am very conservative and don't hesitate to reef or even double reef at the dock before I even raise the sail.
But first I'd find someone to go out sailing w/ you on a day like that and see how the boat handles and reacts to gusts. EVERY boat is different and even the same models can be different depending on how they are laid out and how much load they have.
AND... reefing is just one option (and usually the only option some sailors think of). You can tighten the cunningham (or the halyard if you have more room to raise it), tighten the outhaul, vang and sheet and use the traveler... lots of options if your boat has all those pretty little strings to pull.
HDChopper and Jimmy E like this.
CS 36M DIANTHUS
sailordave is offline
post #28 of 55 Old 07-26-2012
Well, whatever the conditions were 6 hours ago, I hope he gets off the river before 8 because all hell is probably going to break loose in an hour. T-storms are moving in.
They lost a J-24 last year in one...went right to the bottom.
tempest is offline
post #29 of 55 Old 07-26-2012
Captrizzo
Less than 5knots close to zero with gusts 20+ are not uncommon July and August on the Delaware River, sometimes you can see them coming; ripples on the water, cloud banks, change in temperature. They don't last long but I still try to reduce sail before it hits or ride it out. Gust in 10knot winds to 35 are common in the summer.
When its all over I check the wind at PHL, my marina is under their landing approach.
THis was just a few minutes ago:
AT 735 PM EDT...NATIONAL WEATHER SERVICE DOPPLER RADAR CONTINUED TO
INDICATE A LINE OF SEVERE THUNDERSTORMS CAPABLE OF PRODUCING QUARTER
SIZE HAIL...AND DAMAGING WINDS IN EXCESS OF 60 MPH. THESE STORMS
WERE LOCATED ALONG A LINE EXTENDING FROM NEW HOPE TO KING OF PRUSSIA
TO COATESVILLE...MOVING EAST AT 55 MPH.
SEVERE THUNDERSTORMS WILL BE NEAR...
WISSINOMING...TACONY...SOUTH PHILADELPHIA AND PHILADELPHIA
INTERNATIONAL AIRPORT BY 745 PM EDT...
TULLYTOWN...CROYDON AND BRISTOL BY 750 PM EDT...
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #30 of 55 Old 07-26-2012
BarryL's Avatar
Hey,
If you think there are going to be 30 kt gusts you should have a reef in main (and maybe reduce the headsail too, I guess that depends on your boat).
If you have reefed sails and are in 15 kt winds you will go a little slower than if you have full sail up. But, if you have full sail up and get hit with 30 kt winds, you will be on your ear and you can break things too.
Since you asked, if you do have full sail up and get hit with a gust you have two choices. You can pinch the boat up into the wind and feather it there. The sails will flog a little or a lot (depending on how high you point) but the but will be mostly upright and probably not too uncomfortable. If you were on a beam reach and get hit you can ease sheets and run off downwind. You better have a lot of sea room in that case because you will need it.
Barry
SVAuspicious likes this.
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
How do you guys find ACCURATE wind conditions? NewportNewbie General Discussion (sailing related) 48 11-03-2011 01:34 PM
sail plans at different wind conditions for C37 yzlian Pacific Seacraft 0 04-11-2011 11:25 AM
Is there an Internet website that shows wind, tide, water conditions? kldzx9r General Discussion (sailing related) 9 09-22-2007 11:07 AM
Live wind conditions - what are your favorite web sites? tenuki General Discussion (sailing related) 16 08-15-2007 07:33 AM
Wind conditions test sailors (The Hindu) NewsReader News Feeds 0 05-23-2006 04:15 PM
