wind conditions and reefing - Page 5 - SailNet Community
 38Likes
post #41 of 55 Old 09-02-2012
Quirky
Sublime's Avatar
Re: wind conditions and reefing
Originally Posted by AndreasNYC View Post
I am still a little intimidated by trying to put in a reef when I am on the water. When the sails are luffing it I worry I will be hit by them or the jib or the jib lines.
The briefing on this site indicated that you should put the reef in when the sails are luffing. Is it also possible to do while there is wind in the sail? It seems like that would be less drama.
There's different reefing systems and even some you don't even have to leave the cabin for.
This post is made from recycled electrons
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Sublime is offline
post #42 of 55 Old 09-02-2012
If I have crew I prefer to put in a reef in the main while sailing on the jib. Just ease the main until it luffs but keep the jib trimmed. The advantage of this approach is you have full control over the course. I don't like luffing both sails at the same time as you quickly lose way and then it's easy to get backwinded. This approach does not work well with lazy jacks, though.
With the reefing lines all back to the cockpit we can change the reefing in 20s and hardly lose any speed.
If alone, the best way is to heave to. The boat is again stable in attitude to the wind and there is little or no force on the main.
Tempest, jackdale and HDChopper like this.
MarkSF is offline
post #43 of 55 Old 09-11-2012 Thread Starter
How do the lazy jack affect the process?
I had a fully battened sail and have found they like to get stuck on the lazy jacks when I raise the sail.
How do they affect reefing?
Andreas
AndreasNYC is offline
post #44 of 55 Old 09-11-2012
Senior Smart Aleck
jameswilson29's Avatar
I have come to accept my lazyjacks. Now, I simply release the line fully to allow the sail to go where it will when raising it. Once the mainsail is up, I will tighten the lazyjack line a bit so it is not flapping aroundl
It does not interfere with reefing, provided you allow enough slack.
jameswilson29 is offline
post #45 of 55 Old 09-11-2012
jackdale's Avatar
Andreas
The best system is one that allows the lazyjacks to be stowed near the gooseneck after the main is lowered. They are only needed for lowering a sail. They are not needed for reefing. In this picture the lazyjacks are hooked on a cleat.
HDChopper likes this.
jackdale is offline
post #46 of 55 Old 09-11-2012
My old lazyjack system was removed last month, and now I'm finding it much easier to put the mainsail up, and change reefing, especially when close reaching on the jib.
I designed a new system that would allow each side of the lazy jacks to be lowered independently or together. for raising the sail or reefing.The two lines that go up to near the top of the mast would go around blocks, then come back down the cleats on each side of the mast. The old system terminated at the top of the mast.
If you wanted to get really fancy you could bring the two "lazy jack halyards" back to the cockpit.
MarkSF is offline
post #47 of 55 Old 09-13-2012
chef2sail's Avatar
W have ez- jacks which are out of the way at the mast so our full batten main is not hung up on them. After havinbg lazy jacks for years these are a huge improvement. Thye even have a system for deploying from ther cokpit although we dont do that.
You can make these also if you are so inclined, but they really arent that expensive.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #48 of 55 Old 09-16-2012
Not familiar w/ your boat but in lets say 30 knots or more I personally would just use the motor. I've got a Sabre 28 @ 7800 pound displacement, w/ fin keel & 4.5' draft. In 25 knots I would just use the main alone w/ no reef (my dad would have the genoa up as well). I grew up racing w/ my dad so I have a little different perspective. We were once in a race w/ 25 knot winds & 30 Knot gusts. My dad decided to fly the spinnaker, which no one else was doing in the race. It was a lot of fun until we broached but he decided to continue to fly the spinnaker until we broached again & water started pouring into the cockpit. It all depends what your comfortable at. If you feel your heeling to much you can ease the main or reef it or fall down.
JBIZZ is offline
post #49 of 55 Old 09-24-2012 Thread Starter
So I have discovered that putting a reef in my headsail solves 90% of the problem
We where out on Saturday with 5 people on the boat.
I saw the wind was more than predicted so we used the rolling furler to reduce the jib from a 130% (or maybe 150%?) genoa to jib sail size. After that she handled fine in 26 knot winds. Heeled up to 30 degrees while going upwind at a nice clip. (7 knots)
How much difference do you think the extra people made?
Andreas
post #50 of 55 Old 09-24-2012
Senior Smart Aleck
Andreas
It depends on how large your friends are...
Probably made quite a difference, even on a 13K lb. boat with a 34% ballast to displacement ratio. With an 11' beam, you had all that weight positioned 3-5' windward of the center of buoyancy, probably just about in line with the center of the displacement/gravitational pull of the boat.
Of course the weight is high in the boat. Next time, see if they will all huddle belowdecks on the windward side... or in the bilge...
How do you guys find ACCURATE wind conditions? NewportNewbie General Discussion (sailing related) 48 11-03-2011 01:34 PM
sail plans at different wind conditions for C37 yzlian Pacific Seacraft 0 04-11-2011 11:25 AM
Is there an Internet website that shows wind, tide, water conditions? kldzx9r General Discussion (sailing related) 9 09-22-2007 11:07 AM
Live wind conditions - what are your favorite web sites? tenuki General Discussion (sailing related) 16 08-15-2007 07:33 AM
Wind conditions test sailors (The Hindu) NewsReader News Feeds 0 05-23-2006 04:15 PM
