wind conditions and reefing - Page 6 - SailNet Community
 38Likes
post #51 of 55 Old 09-24-2012 Thread Starter
Re: wind conditions and reefing
I was thinking I would strap them to the bottom of the kheel for maximum leverage.
Actually our cockpit is pretty small so where where sitting 3 on the high side and 2 on the low.
A
AndreasNYC is offline
post #52 of 55 Old 09-24-2012
In that case the effect is likely to be minimal at best, and could even make the boat tip more. The guys on the high side, when heeled, could be over the centre of mass, while the low side have a considerable arm. As the boat heels more, mass higher up has the effect of reducing the righting moment.
MarkSF is offline
post #53 of 55 Old 09-25-2012
AdamLein's Avatar
Presumably the folks on the high side are as far or farther from the axis of rotation than the folks on the low side. So their righting arm is as long or longer.
I say "as far or farther" because the center of buoyancy shifts to leeward, which I think implies that the axis of rotation shifts to leeward as well.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #54 of 55 Old 09-25-2012
Your first paragraph presumes wrongly that righting arm is only related to distance from axis of rotation. There's a vector component too. Righting moment is proportional to the horizontal component of the distance, as it's gravity acting on the weight, doing the work.
Think of 3 people on each side, with the boat at an extreme angle of heel. The 3 on the high side could be directly over the centre of rotation and despite being a long distance away from it, the horizontal component of their distance is zero and hence they provide no righting moment.
The 3 on the low side are the same distance from the centre of rotation but their horizontal component is maximised. They are making the boat heel more.
Generally the effect of ALL weight above the waterline is to reduce the righting moment, and the more the boat is heeled the more the effect.
The exception is when the weight is on one side, but the effect of that still drops as you heel and can reverse in effect at extreme angles.
MarkSF is offline
post #55 of 55 Old 09-25-2012
AdamLein's Avatar
It does not. I can make the same argument using only the horizontal component of the distance, which is what I was actually intending.
I guess what I'm not sure about is the vertical location of the axis of rotation, relative to the crew's COG.
AdamLein is offline
How do you guys find ACCURATE wind conditions? NewportNewbie General Discussion (sailing related) 48 11-03-2011 01:34 PM
sail plans at different wind conditions for C37 yzlian Pacific Seacraft 0 04-11-2011 11:25 AM
Is there an Internet website that shows wind, tide, water conditions? kldzx9r General Discussion (sailing related) 9 09-22-2007 11:07 AM
Live wind conditions - what are your favorite web sites? tenuki General Discussion (sailing related) 16 08-15-2007 07:33 AM
Wind conditions test sailors (The Hindu) NewsReader News Feeds 0 05-23-2006 04:15 PM
