Close call! Who had rights? - Page 4 - SailNet Community
 25Likes
post #31 of 60 Old 10-10-2012
RichH's Avatar
Re: Close call! Who had rights?
Im just going from memory here ... look for the dayshapes for dredges, etc. Im pretty sure the dayshapes for dredges include 'color'.
RichH is offline
post #32 of 60 Old 10-10-2012
jackdale's Avatar
I should have looked here. Rule 27a - Vessels Not Under Commandi
http://www.navcen.uscg.gov/?pageName=nr_27d
All black.
jackdale is offline
post #33 of 60 Old 10-10-2012
EJO
Dutchman
EJO's Avatar
Originally Posted by PBzeer View Post
I have one simple rule ... I don't care who is "in the right", I do what ever is necessary to avoid a collision. Being right doesn't do ya much good if you're underwater.
I don't expect anything, from anyone else, whether I should be able to or not. My boat, my responsibility, period.
WELL SAID. It's like sailing across a 150' M/V I would avoid that as tonnage wins. AVOID AVOID AVOID no matter who is right. Nothing bad happened so it doesn't matter who was right.
Try this motor drifting on the 4th of july in the dark with a 1000 boats on Lake Michigan of which 50 or so have no navigation lights and only know how to catch fish or water ski/tube going CCW on a small inland.
You won't see the fireworks as you are to busy keeping an eye on other boats even anchored or not.
Skipper E-J
S/V "Sailmates" 1973 IRWIN 32 Classic
I want to live and sail forever, so far so good[/SIGPIC]
EJO is offline
post #34 of 60 Old 10-10-2012 Thread Starter
L124C's Avatar
Not to go deeper into the weeds on the "vessel under power/command" issue. However, prior to the incident in the OP (this was an eventful day), we were clipping along close hauled. I had a novice sailor at the helm. We were headed toward a spectator sailboat in the distance, sitting by itself without sails or anchor. I noticed my guy doing the classic rookie move of heading up to avoid the obstacle, without trimming the sails (or in this case, tacking). I told him he had to maintain course, as he was "taking his foot off the gas" and giving up momentum by heading up, possibly disabling us from taking evasive action (in this case, tacking) should the give way boat not move. He asked, "Well, what if the other boat is disabled?"(a moot point, as we simply would have pinched up or tacked). I replied: "If he's disabled, he better start waving his arms or something other than sipping on that beer in his hand!"
Point being, given engine failure, you may not have time to hoist day signals (and I'm certainly not hoisting the only "balls" on my boat, wrong color anyway!), but I expect some signal that things are not normal, and that the regular rules do not apply.
In addition, it always amuses me when inexperienced helmsmen change course to avoid an obstacle (often very early) without mentioning it, or trimming, as if they were driving a car. I've had this conversation with this guy before, and he's no dummy. Sometimes I'm not sure they realize they are doing it!
Do other skippers notice this? If so, how do you convey to novices that a sailboat needs way on to maneuver around an obstical?
L124C is offline
post #35 of 60 Old 10-10-2012
chucklesR's Avatar
L124C,
Teach them to fall off rather than point (if appropriate) - you can always point higher later.
Also teach them to communicate everything they do other than maintain course and speed.
chucklesR is offline
post #36 of 60 Old 10-10-2012
jackdale's Avatar
Before altering course we teach helmsmen to issue commands:
"bearing away, ease the sheets"
"heading up, harden the sheets"
"prepare to gybe"
"prepare to come about"
The only one without a preparatory command is "heaving-to."
The way issues is crucial under power when maneuvering at slow speed. On a fin keel I like about .5 knots to maintain steerage. On full keels, you may need 1 knot. It does vary from boat to boat.
We also teach maneuvering in close quarters so that they can use prop walk to turn a boat on its keel.
Pinching is something to be avoided; you slow down and make leeway.
chef2sail likes this.
jackdale is offline
post #37 of 60 Old 10-10-2012
jackdale's Avatar
Originally Posted by chucklesR View Post
L124C,
Not a phrase I like to use when on the water.
jackdale is offline
post #38 of 60 Old 10-11-2012
Exactly how is the other boat to note whether or not the transmission is engaged?
If I can see exhaust and water from the stern so I know the motor is running and therefore it's a motor boat, simply knocking it out of gear does NOT enable a skipper to say I'm a sailing vessel and have right of way.
Rule 14 applies here, two POWER driven vessels meeting head on, both turn to the right. No restrictions had been posted.
Rule 17, everything to avoid a collision, not play legal games.
I really don't care about the responses you got via email.
Really?? I would think the big white sails would be a pretty good indication the vessel was under sail
The exhaust does not make the vessel a powerboat.... Only mechanical propulsion can do that.... Btw... How do you know the water coming out the aft end of that boat under sail isn't from a generator.... ??
wise4 is offline
post #39 of 60 Old 10-11-2012
Racing terms for new students, do's and don'ts--
"Rail Meat"---yes, they think it's funny. So do I. Also quicker to yell than "come on up to windward now"
"Blow the guy"--no. Just no.
"Blow the vang"--better, but what's a vang again?
"Harden up"--not at first, it hurts their feelings. They get over it later once they get what you meant.
"Gimme some tail"--careful, you may get the winch handle where you didn't want it..
"Jibe Ho"-- permissible, but tell your female students it's not Hip-hop first.
"Fall off a little"--you're right, not to be done till you explain that all "up" and "down" clone words no longer mean vertical, but rather horizontal and either toward or away from the Wind God's mouth..
I'm still waiting to use "scandalize the main", but the opportunity hasn't presented itself..
jackdale, MarkSF and Brewgyver like this.
nolatom is offline
post #40 of 60 Old 10-13-2012 Thread Starter
L124C's Avatar
L124C,
It's not a matter of point of sail (though in this case we had another small obstacle to Leeward, called Alcatraz!). I wouldn't want them to fall off without letting out sail either.
I was hoping the other boat would move and/or we would get a header and could maintain trim/course.
I do teach them to communicate when maneuvering, and they do when tacking, gibing etc,.
As I indicated, this almost seems subconscious on their part. As if subconsciously they think: "I'm concerned about that obstacle in the distance and I'll just ease around it and no one (including the laws of physics) will notice". It's hard to believe, but I honestly don't think they know they are doing it. I've seen it too often to be coincidence. I think it relates to the fact that most of their experience is behind the wheel of a car.
1. They don't calibrate that on a sailboat (unlike in a car), that obstacle is a long way off.
2. In their car they simply turn the wheel to avoid an obstacle and apply the brake or gas as needed. We of course know that changing course without trimming amounts to taking your foot off the gas and (eventually) your hands off the wheel. Regarding brakes, well....they weren't an option on my boat.
L124C is offline
Close Call for a Sailboat on Park Point - WDIO-TV NewsReader News Feeds 0 05-06-2012 11:00 PM
Close Call for a Sailboat on Park Point - WDIO-TV NewsReader News Feeds 0 05-05-2012 10:50 AM
Fire Onboard, Very Close Call! Leocat66 Gear & Maintenance 30 01-23-2012 07:56 PM
Close call as Coast Guard fishes anglers out of sea - New York Daily News NewsReader News Feeds 0 04-16-2007 12:15 PM
Baldwin and Inoue survive a close call (San Diego Union-Tribune) NewsReader News Feeds 0 01-27-2007 06:15 AM
