Crash jibe buffer - Page 2 - SailNet Community
 4Likes
post #11 of 27 Old 12-11-2012
Re: Crash jibe buffer
The Wichard Gyb'easy boom brake is a pretty ingenious and simple device. Outrageous money for a simple molded piece of aluminum and some stretch line, but patents exist for a reason. The only downside is they are limited to 400-500 sf mainsails. Don't know why they haven't made a larger one.
St Anna likes this.
Jeanneau 54DS
Minnewaska is offline
post #12 of 27 Old 12-11-2012
ASA and PSIA Instructor
Aside from the hardware damage that an accidental gybe can produce, it is also probably the largest single cause in sailling of personal injury and death, for example;
Sail-World.com : British sail-trainers on trial over injury/dramatic rescue of novices
sailingfool is offline
post #13 of 27 Old 12-11-2012
St Anna's Avatar
Ditto - I have this system. It works well so far **~9200nm} but time may tell...
St Anna is offline
post #14 of 27 Old 12-12-2012
jimrafford's Avatar
I have boom end sheeting w/ the traveler in the middle of the cockpit. An accidental jib is unacceptable.
I installed a dutchman boom brake on the current boat and the previous one. Love it! Always there. It's run to a secondary winch. Want to lock the boom. wrap the winch and lock it down. Want to jibe. Release the winch, jibe and lock it down again. No worries. Never have an accidental jibe again.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #15 of 27 Old 12-12-2012
Jim
I have exactly the same setup and I love it! Although I don't have it always on, only beyond a broad reach. But the lines are always led through it so it takes me less than 5 minutes to 'activate' it. Wouldn't want to do without it.
MastUndSchotbruch is offline
post #16 of 27 Old 12-18-2012
I was on a down wind run some years ago, and we jibed and broke the boom. Now I have a preventer. I have sailed on boats where they do not prevent the boom, and do feel uneasy.
luck66 is offline
post #17 of 27 Old 12-28-2012
casey1999's Avatar
Concerning getting hit by the boom, why is the boom so low? Realize one would loose some sail area, but raising the boom a foot or two could mean the difference between life or death. Some boats have booms that are high enough to not be a danger, others are below head height when standing in the cockpit. I am considering when I make replacement sails to raise the boom up a foot, to clear my head.
Pros and cons?
casey1999 is offline
post #18 of 27 Old 12-28-2012
jackdale's Avatar
Pros and cons?
Many 1980's boats had lower booms and smaller dodgers.
Race boats will have lower booms (and no dodger) for the sail area.
One downside to raising the boom is that it raises the CofE of the main, increasing the tenderness of the boat. That is mitigated somewhat by a smaller sail area assuming you do not g with a tall rig.
jackdale is offline
post #19 of 27 Old 12-28-2012
Glad I found Sailnet
Bene505's Avatar
Originally Posted by davidpm View Post
I help deliver a 50' boat a couple weekends ago. We sailed all night on a run wing on wing. Wind was about 15 knots. Under those conditions I would usually rig a dock line from the boom to the rail as a preventer as it is really hard to see the sails in the dark.
There are some disadvantages having a preventor that can't be released easily too but still it seems the lessor to two evils if you don't have a real boom brake.
All he did was leave the traveler uncleated on both sides. When we did inevitably jibe the traveler pulling it's line through the blocks has a pretty good damping effect.
I'm not saying I would do it myself except in very light air but it did seem to work. The rig stayed up.
That trip was with me. David joined after I sailed all day solo over to pick him up. He's a great help and I highly recommend him.
We have a boom break in the cockpit locker. I didn't feel we needed it yet, but would have pulled it out (or rigged a preventer) at the least suggestion. I like using it and the special line is used for only that purpose. We have the smaller mast = smaller sails, by the way, and the wind was unchanging in speed and direction and not gusting at all. The boom is above the full bimini hardware and the solar panel.
(I think boom brakes are far safer than preventers, by the way.)
The traveller setup was not intentional as a boom break.
More importantly is that all suggestions are welcome at any time. Maybe I should add that as a standard practice, to periodically solicit ideas on what we could do to sail safer or better. I like it!
Regards,
Brad
Bene505 is offline
post #20 of 27 Old 12-30-2012
Over Hill Sailing Club
smurphny's Avatar
After multiple tries at various attach points for a preventer, decided that it was essentially a lousy idea, at least on my narrow boat: too much point load on the boom, boom would snap if buried, no good way to immediately release, etc. I have welded up a ladder device, similar to the one mentioned above. It's constructed of 1/2" 316 s.s. and attaches to a large plate I designed to spread loads out along the boom. There is no need for an elastic line that I can see as long as the sides of the working triangle are exactly equal. Using a piece of relatively stretchy 1/2" (old sheet) line should account for any minor discrepancies. Am going to install this in the spring and give up on trying to tie the boom off to something forward.
smurphny is offline
Bright work buffer Minnewaska Gear & Maintenance 28 04-22-2013 10:30 PM
NONSUCH 22 - Jibe preventer Essemm65 SailNet FAQ 3 04-10-2012 09:47 PM
jibe preventer jimmd Seamanship & Navigation 4 08-10-2007 02:00 PM
jibe question saurav16 Learning to Sail 6 06-28-2007 08:49 PM
Perfecting the Jibe-Set Dean Brenner Racing Articles 0 10-30-2003 08:00 PM
