Rule 23a question - SailNet Community
 1Likes
post #1 of 19 Old 12-18-2012 Thread Starter
davidpm's Avatar
Rule 23a question
In the "Wing" One-minute guide book on page 34 it says that for power-driven 50m or more the second white mast head can be an all-around so you don't need a separate stern light for inland.
At least that is how I interpret the graphic below.
International requires a separate stern light.
The end result is the same light configuration visible.
Do you know what page it is on in the USCG rules book, I could not find it?
Not sure why it matters as they look is pretty much the same except for the height of the stern light.
davidpm is offline
post #2 of 19 Old 12-18-2012
jackdale's Avatar
Re: Rule 23a question
Under rule 23 (a) a separate stern light is required.
Rule 23 - Power-driven Vessels Underway
(a) A power-driven vessel underway shall exhibit (click on icon to see picture
(i) a masthead light forward;
(ii) a second masthead light abaft of and higher than the forward one; except that a vessel of less than 50 meters in length shall not be obliged to exhibit such a light but may do so;
(iii) sidelights: and
(iv) a sternlight.
Navigation Rules Online
BTW - a masthead light is 225 degrees
Rule 21 - Definitions
(a) "Masthead light" means a white light placed over the fore and aft centerline of the vessel showing an unbroken light over an arc of the horizon of 225 degrees and so fixed as to show the light from right ahead to 22.5 degrees abaft the beam on either side of the vessel, except that on a vessel of less than 12 meters in length the masthead light shall be placed as nearly as practicable to the fore and aft centerline of the vessel.
jackdale is offline
post #3 of 19 Old 12-18-2012 Thread Starter
davidpm's Avatar
I found it!
"(d) A power-driven vessel when operating on the Great Lakes may carry an all-round white light in lieu of the second masthead light and sternlight prescribed in paragraph (a) of this Rule. The light shall be carried in the position of the second masthead light and be visible at the same minimum range."
Page 51
Very subtle point.
davidpm is offline
post #4 of 19 Old 12-18-2012
jackdale's Avatar
Subtle indeed
There is also a Canadian modification
In the waters of the Great Lakes Basin, a power-driven vessel
when underway may, instead of the second masthead light and
sternlight prescribed in paragraph (a), carry, in the position of
the second masthead light, a single all-round white light or two
such lights placed not over 800 millimetres apart horizontally,
one on either side of the keel and so arranged that one or the other
or both shall be visible from any angle of approach and for
the same minimum range as the masthead lights.
http://laws-lois.justice.gc.ca/PDF/C.R.C.,_c._1416.pdf
Where Canadians and Americans share waters there is often congruence between Inland Rules and Canadian modifications.
jackdale is offline
post #5 of 19 Old 12-19-2012
Courtney the Dancer
jrd22's Avatar
I've often wondered what practical reason there is for the lighting rules to be different for inland than anywhere else. I can almost understand the towing and pushing differences, but for a power driven vessel? David- even studying for my license I never picked up on the second mast head/all round light variance for inland, good eye.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #6 of 19 Old 12-19-2012 Thread Starter
davidpm's Avatar
Thanks but it wasn't me it was Charley Wing.
His book makes these little differences stand out.
Also it is not inland it is great lakes for the all around.
Even more subtle that you thought huh?
davidpm is offline
post #7 of 19 Old 12-19-2012
L124C's Avatar
One example (as I recall) is allowing a tri colored mast head light for sailing smaller boats offshore, but only running lights for inland waters. Didn't make sense until I realized that in more restricted waters, skippers may not be far enough away to be looking 40 or 50 feet in the air for lights. In addition, the mast head light makes sense in big seas.
L124C is offline
post #8 of 19 Old 12-19-2012 Thread Starter
davidpm's Avatar
Tri-color lights are allowed for both offshore and inshore under 20 meters.
One advantage is that the lights distract the helmsmen less high up.
A side light can reflect off the head-sail at deck level causing glare.
davidpm is offline
post #9 of 19 Old 12-19-2012
FSMike's Avatar
Originally Posted by davidpm View Post
Tri-color lights are allowed for both offshore and inshore under 20 meters ---
I didn't know that. When did that take effect, or have I been oblivious for ever?
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #10 of 19 Old 12-19-2012 Thread Starter
davidpm's Avatar
Jackdale is an instructor, I'm just reading the book but here is the paragraph, no distinction between international or inshore
(a) A sailing vessel underway shall exhibit:
(i) sidelights;
(ii) a sternlight.
(b) In a sailing vessel of less than 20 meters in length the lights prescribed in paragraph (a) of this Rule may be combined in one lantern carried at or near the top of the mast where it can best be seen.
davidpm is offline
Rule 10 and rule 18? JohnnyJupiter Racing 11 08-28-2012 01:44 PM
Nav Rule Question on the Use of Radar on Sailboats Triquetra Seamanship & Navigation 13 07-21-2011 05:01 PM
Start rule question different fleets NotQuiteCapnRon Racing 21 11-27-2010 10:39 AM
Rule Question please d212 Racing 5 02-03-2007 09:59 AM
The Rule of 60 John Rousmaniere Her Sailnet Articles 0 08-08-2004 08:00 PM
