Flaking the Main Sail - Page 4 - SailNet Community
 2Likes
post #31 of 40 Old 05-23-2013
chef2sail's Avatar
Re: Flaking the Main Sail
Originally Posted by outbound View Post
Chef got to accept your experience with your boat(s). Never had e-z jacks but have had several boats with lazy jacks and tried 3 and 4 leg systems on one as it gave me trouble. Current boat has mast pulpits so I guess I can bring jacks out there if necessary.Got to admit sometimes lazy and haven't brought them forward when just day sailing. Guess it one of those things if you ask three people you get four opinions. Picking up the boat this sunday so will not be dependent on other folks opinion in a few weeks about ease of use. Will take a few years before having an opinion about wear. Still as line goes through grommets and lies softly on sail not too worried. More concerned the sail will likely fold in just about the same place every time and that maybe hard on the fibers/coatings. spoke with lofts in MA and Cali about dutchman. Said harder to set up right and needs to be set up right to function correctly. if not done correctly it's a headache.
So true about the multiple suggestions of things which work when rigged properly
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #32 of 40 Old 05-23-2013 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Thanks everyone for all the input. I will try the flaking of the luff as you slowly lower the sail and see how that works.
brokesailor is offline
post #33 of 40 Old 05-23-2013
s/v Ilya
arknoah's Avatar
Originally Posted by T37Chef View Post
If there's a good bit of wind I just lower it fast and cover it before I get back to the slip so no one can see how bad a flake job I did LOL
Yeah. I single hand almost all of the time, and I can't say that the way I flake the main would make any purist very happy. I do try to fix it up once I'm back in the slip, but when I'm just motoring in after a nice sail, it's not pretty!
Ilya's Adventures:
____________________________
And straight on 'til morning
arknoah is offline
post #34 of 40 Old 05-26-2013
first sailed january 2008
northoceanbeach's Avatar
Originally Posted by Alex W View Post
One trick for releasing the halyard slowly when the clutch is at the cockpit and you are at the mast is to stand on the exposed halyard routed on the cabin deck. You could even install a cam cleat on the mast which holds the halyard there to make this easier. Harken has that recommendation here for the spinnaker halyard, but it would also work for the main:
This is exactly what I do. Foot and all.
Harken
The other is to flake it well at the mast (making sure to get the alternating flakes there), then fix it up at the far end of the boom from the cockpit. When I'm singlehanding it is hard to flake it properly at both ends by myself, but if I do the mast side first then it goes easily.
I start at the ban and pull taught each flake and the mast part seems to take csre of itself.
If you find it hard locating the right flake points at the far end then you could get them right once and mark them to make it easier to find them the next time.
I love my lazy jacks. I think if you are careful and flake the sail in the same place everytime it will remember that. Mine with jack pretty much flakes itself. Even in wind. I just tidy up a but and put the sail ties on.
northoceanbeach is offline
post #35 of 40 Old 05-26-2013
Mermaid Hunter
SVAuspicious's Avatar
I have retractable lazy jacks and a Selden track system on the mast. All controls are at the mast. Luff is about 55 feet.
I drop 10 or 15 feet of the main, stop the clutch, go back to flake the bottom of the sail and put a tie or two in, look around, adjust the auto-pilot, and head back forward.
Lather, rinse, repeat. I drop the main in three sections - 10-15 feet, 15-20 feet, and the rest.
Singlehanded it takes about four minutes; two-up it is less than three. I pull the jacks forward and put on the sail cover at the dock or at anchor.
I tried dropping it all and sorting it out but the weight of all that fabric was too much work for a lazy guy like me.
brokesailor likes this.
SVAuspicious is offline
post #36 of 40 Old 05-26-2013
I do it pretty much as described by multiple folks. Namely, I put one wrap on the winch and take the halyard fwd w/ me. Lower the sail flaking side to side. Go back in the cockpit, pull the boom down tight and to the side and flake the leech. I have SHARPIE marks on the leech showing where to put the sail. Tie it off and VOILA!
I am in the process of making my own lazy jacks out of Amsteel. They will be retractable and spliced to themselves so there will be no hardware. No chaff on the sails and I can pull them fwd to keep them out of the way. 1/8" is a little harder to splice but inexpensive, light and less obtrusive.
Dutchmen systems IMHO suck. More holes in the sail. The sail always folds the same way and they're pricey. (I alternate how I flake the sail) Maybe for casual cruiser types they're okay, but I hated it when I sailed a boat w/ a Dutchmen.
(and not the guys from Holland!)
CS 36M DIANTHUS
sailordave is offline
post #37 of 40 Old 05-26-2013
We have ez-jacks and to mitigate the problem of battens catching on the ez-jacks lines, I attach long bungees from the top most rings to the shrouds which holds the ez-jacks lines further away from the sail.
TejasSailer is offline
post #38 of 40 Old 05-26-2013
Another trick is to terminate the jacks (of whatever sort) off the mast and outboard on a spreader at the upper connection . This widens the gap between them easing the issues hoisting.
T37Chef likes this.
Faster is offline
post #39 of 40 Old 05-27-2013
Tundra Down
downeast450's Avatar
An interesting collection of techniques! I would like to see each procedure in fast motion video!
Now for the gaff rig? Gaff comes down last.
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #40 of 40 Old 05-27-2013
outbound's Avatar
Early days on the dutchman. In pocess of commissioning the boat but in spite to what's said above dutchmen was easy to rig and on tests ( admittedly not offshore) seems to work just fine. looks like it will ease reefing considerably. should have better idea on friday.
s/v Hippocampus
Outbound 46
outbound is offline
Main sail sailorboy2 Hunter 1 12-05-2010 08:58 PM
main sail help diverdad69 Gear & Maintenance 3 06-07-2009 11:53 PM
Dutchman Sail Flaking System Problem Trescool Gear & Maintenance 4 07-29-2007 01:41 AM
new main sail mastercpo Gear & Maintenance 0 11-23-2002 12:35 PM
