Flaking the Main Sail - SailNet Community
 2Likes
post #1 of 40 Old 05-21-2013 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
One of my least favorite jobs is flaking the main after a sail. I have a new, stiff main. Even with lazy jacks it is quite the chore. Anyone have that magic bullet of tips to flake?
brokesailor is offline
post #2 of 40 Old 05-21-2013
Re: Flaking the Main Sail
Agreed, not fun. Its a different experience on each boat, as deck access to the length of the boom is different. If you have the halyard at the mast, you just have to do it a few feet at a time and make the flakes large enough that they drape a bit and stay in place. I know, give it some wind or a boom that is moving and it can be a disaster. If the halyard clutches off in the cockpit, its a minimum two person job.
Lazy Jacks drive me nuts when raising the main, but they are useful to drop it, especially when shorthanded. You might just add a stack pack or equivalent to the bottom, so that you can just dump the sail into it, without bothering to flake and then just zip the stack pack over the top.
Jeanneau 54DS
Minnewaska is offline
post #3 of 40 Old 05-21-2013
no longer reading SailNet
Alex W's Avatar
One trick for releasing the halyard slowly when the clutch is at the cockpit and you are at the mast is to stand on the exposed halyard routed on the cabin deck. You could even install a cam cleat on the mast which holds the halyard there to make this easier. Harken has that recommendation here for the spinnaker halyard, but it would also work for the main:
http://www.harken.com/content.aspx?id=3912
The other is to flake it well at the mast (making sure to get the alternating flakes there), then fix it up at the far end of the boom from the cockpit. When I'm singlehanding it is hard to flake it properly at both ends by myself, but if I do the mast side first then it goes easily.
If you find it hard locating the right flake points at the far end then you could get them right once and mark them to make it easier to find them the next time.
Alex W is offline
post #4 of 40 Old 05-21-2013
Rhys05's Avatar
We gave up on flaking (no lazyjacks) pretty early on and now just roll the mainsail. Disadvantage being that it is almost definitely a two person job.
Rhys05 is offline
post #5 of 40 Old 05-21-2013
T37Chef's Avatar
I find it easiest and results in the best finished job if I alternate/flake it at the mast as I lower the main into the EZ Jax (a retractable version of Lazy Jax) and then once its down clean it up on the aft end of the boom by pulling the main aft and tidying up the folds. I tie it from the aft forward then lower/retract the EZ Jax and store them then throw the sail cover on and its done.
If theres a good bit of wind I just lower it fast and cover it before I get back to the slip so no one can see how bad a flake job I did LOL
Shawn
T37Chef is offline
post #6 of 40 Old 05-21-2013
DrB
Your main must be bolt rope not slugs. I can't see how one would do this with slugs.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #7 of 40 Old 05-21-2013
Rhys05's Avatar
That is correct. Slugs would make it easier to flake and impossible to roll.
Rhys05 is offline
post #8 of 40 Old 05-21-2013
I don't discuss my member
zz4gta's Avatar
I have slugs on my race main and roll it. I just pull it out of the mast track. Does take a little more time to hoist, but is easier to drop and reef. On my boat anyway.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #9 of 40 Old 05-21-2013
chucklesR's Avatar
I normally just drop (have lazy jacks) then flake it well when I have time. Being a center cockpit I have a high boom that makes access to the sail aft a real climb. I almost need a step ladder at the mast.
I've found that really tight lazy jacks as well as a taunt outhaul make a big difference in keeping the sail on the boom.
A slow drop is just not an option more often than not because by the time I drop sail I can't just meander along pointing into the wind due to narrow or thin water and other traffic.
The idea of getting a good flake on it and then marking the main at the mast is a good one. Now I just have to get a good flake and a sharpie.
chucklesR is offline
post #10 of 40 Old 05-21-2013
outbound's Avatar
get a dutchman- then don't worry - be happy
s/v Hippocampus
Outbound 46
outbound is offline
Main sail sailorboy2 Hunter 1 12-05-2010 08:58 PM
main sail help diverdad69 Gear & Maintenance 3 06-07-2009 11:53 PM
Dutchman Sail Flaking System Problem Trescool Gear & Maintenance 4 07-29-2007 01:41 AM
new main sail mastercpo Gear & Maintenance 0 11-23-2002 12:35 PM
