Go Back   SailNet Community > General Interest Forums > Seamanship
  #21
Old 08-30-2006
I think it is fairly simple to install. Someone at my friend's marina did it a couple of months ago, while I was there helping step their mast. IIRC correctly, it just slides into the existing track... no real complicated installation issues... from what I saw.
  #22
Old 09-03-2006
Jotun's Avatar
Space cadet
Jotun is on a distinguished road
I have the same problem, though it is not due to dirt or grime in the track. The slugs seem to get pulled at an angle and lock up just above the slot. I've never been out alone, so it's not much of a problem. Someone just goes up to the mast and feeds the slugs up, but I'm not sure I could raise the main alone.
  #23
Old 09-04-2006
Another solution is to get longer slugs. Most tracks can accommodate slightly longer slugs than you may have on your existing sail. The longer slugs tend not to twist as much and don't jam as easily.
  #24
Old 09-04-2006
CatSailor from Oz
alanl is on a distinguished road
Send a message via Skype™ to alanl
Last weekend I usee JohnR's trick of cleaning out the track and was amazed at the difference it made. It was not quite as simple as it sounded, because getting into the track would have meant removing all the slugs first, so I cut the binding off the top slug and resewed it after doing the job
It was not easy to get the cloth patch inside the track but persistence paid off. A local product called "Gumption" comes in a damp paste and by wetting the patch before liberally coating on one side, it was possible to "stick" it to the inside of the groove and still get the slug over it. Some whipping twine kept it in place while being raised and lowered. This was repeated several times with fresh patches, then every slug was coated with "zipper" grease and the main raised. Wow - what a difference!
Thanks John. Also thanks to Sailing Dog for comments about the plastic insert
AlanL
  #25
Old 09-04-2006
Glad to help.
You may post attachments
You may edit your posts
Raising sail alone dahoser Learning to Sail 17 08-14-2005 02:37 PM
Main Sail Shape newuser Learning to Sail 5 10-30-2004 03:45 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
main halyard Sailmale Gear & Maintenance 5 06-20-2002 09:25 PM
recutting my blown out main jollymonjeff Seamanship 6 12-27-2001 09:38 AM
SEO by vBSEO 3.6.1
