Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
User Name
  #11 (permalink)
Old 05-10-2007
doctom's Avatar
doctom doctom is offline
doctom is on a distinguished road
does anyone have an opinion on whether it is it advisable or even possible to set up a windvane for self steering to my emergency tiller setup? the position of my helm, winches and coaming will have to make for some pretty intricate line setup to get a windvane to my wheel....but would be exceedingly simple to get to a aft pointing tiller....
mike
  #12 (permalink)
Old 05-10-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Dotcom-
It would help if you said what kind of boat you had... without that... it makes it pretty hard to guess if anything will work. BTW, probably better off starting a new thread just for that... this one was pretty dead.
If you're new to the Sailnet Forums... please read this POST.
  #13 (permalink)
Old 05-15-2007
Joel73's Avatar
Joel73 Joel73 is offline
1987 Pearson 27 #11
Joel73 has a spectacular aura aboutJoel73 has a spectacular aura aboutJoel73 has a spectacular aura about
As another newbie around here i found this thread quite interesting... a good one to revive because of safety. We don't have an emergency tiller so that has become the next project... I wonder what kinds of wood i should consider? Oak is good and solid... would that be a good choice?
"It occurred to me by intuition, and music was the driving force behind that intuition. My discovery was the result of musical perception." (When asked about his theory of relativity) - Albert Einstein
TownDock RiverCam: Oriental, NC
  #14 (permalink)
Old 05-15-2007
SVDistantStar's Avatar
SVDistantStar SVDistantStar is offline
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
This is one of the downsides of the location of my pedistal(i know i cant spell). It has been moved far aft in my cockpit, rendering a tiller un-useable. My boat is a Pearson 36, and they have a pedistal in the front of the cockpit from the factory. Im going to move it back to this spot and make a tiller for the rudder. The top of my rudder shaft is square and there is a large deckplate above it to access it. I hate it when people change things around and dont even think of whats going to come from it.
  #15 (permalink)
Old 05-15-2007
You could easily make the rudder out of pipe stock...since it is an emergency tiller it would probably make far more sense to make it out of something that won't degrade in storage. Most wood tillers will eventually need far more maintenance, and being a piece of emergency gear, it will probably be out of sight/out of mind...and fail to get it.
  #16 (permalink)
Old 05-15-2007
abbarr's Avatar
abbarr abbarr is offline
abbarr is on a distinguished road
Out of sight out of mind is a great reason to check on the state of your emergency tiller. When I checked it on a friend's boat, prior to cruising up the coast, i found that the coupling had deteriorated to the point of being completely useless. It was one of the first things I put to the test on my boat.
  #17 (permalink)
Old 05-15-2007
Joel73's Avatar
1987 Pearson 27 #11
SD- Great idea and maybe easier to make than a wooden copy of my current tiller. thanks.
  #18 (permalink)
Old 05-15-2007
Glad to help Joel. Save the pretty laminated wood for a tiller that's going to see the light of day in normal use...
  #19 (permalink)
Old 05-24-2007
teshannon's Avatar
teshannon teshannon is offline
teshannon has a spectacular aura aboutteshannon has a spectacular aura aboutteshannon has a spectacular aura about
Emergency Tiller
I took EscapeArtist's excellent advice and rigged the emergency till on my Tayana 42 yesterday. Ah, that is a lovely chartplotter I had installed! If I punch a hole through it I could probably get that tiller rigged. Actually, given the aft location of my helm I don't think the tiller would have worked even without the plotter. The only way I can rig it, without cutting it down to an unusable length, is with the tiller out to port or starboard. I haven't tried to stear it that way yet but it seems to me the helm interfering with the tiller issue is probably not unique to my boat.
Excellent advice from EA and others, you don't want to be finding suprises when you really need it.
Tom Shannon
S/V Orion
  #20 (permalink)
Old 05-24-2007
Giulietta's Avatar
Giulietta Giulietta is offline
AD MEMORIAM COURTNEY 2008
Giulietta is a jewel in the roughGiulietta is a jewel in the roughGiulietta is a jewel in the roughGiulietta is a jewel in the rough
I don't have an emergency tiller...
Em memoria de Courtney
Filha de Deus
Display Modes
vB code is On
KISS? or ... why a wheel? jbarros General Discussion (sailing related) 16 07-05-2003 10:21 AM
tiller pilot for 38 Ingrid obiec Gear & Maintenance 0 05-10-2003 06:30 AM
Killer Tiller masslobsterguy General Discussion (sailing related) 7 04-09-2002 10:52 AM
What Would You Buy For 70 Grand Dav-O Buying a Boat 22 03-26-2002 09:11 PM
tiller head for a Galilee? TominBC Gear & Maintenance 0 01-30-2001 12:38 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
