09-24-2008
If you anchor by the stern, then you can use the spinnaker for swinging out over the water.
If you anchor by the bow, then use a ridding sail to keep your vessel's horsing at anchor to a minimum.
Note: Horsing is the correct term here. Not sailing at anchor.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
