We have an Ericson 34 with a Dutchman system. I found the argument that I previously heard about difficult mainsail removal and installation to be a red herring. Removing the sail is a cinch. You just loosen one screw for each Dutchman
line and then tug the fishing
line back out of the guides in the sail. In our case there are two
lines. Re-installing the mainsail is a little more effort than the removal since you actually have to thread the Dutchman
line through the guides in the sail in the proper order from the top of the sail down, but it's really quite simple. The guides are several feet apart so their aren't very many to deal with. I'm going to mark the starting side of the first guide for each
line so there's nothing to figure out next time I have to thread it. Once you thread through the first guide the rest is obvious.
There may be something to the wear issue. I have studied the system underway and I just don't see how there would be much if any wear induced by a properly adjusted Dutchman. With the sail raised, the Dutchman
lines are slack so it isn't like there's any leverage against the sail material. We shall see.
On the plus side, I certainly don't miss having the battens catch on the
lazyjacks when raising in rougher conditions with the sail flagging. Then when you do douse the main, flaking is easier since the sail is more restricted in it's collapsed movement on the boom.
From a simplicity standpoint it's hard to criticize the Dutchman either. It has much less
rigging parts than the
lazy jacks. It's true that the topping lift has to be converted from a single
line into a closeline arrangement, but that makes it easy to replace the Dutchman
lines if they wear out.
Unfortunately, the Dutchman system has a few problems that LazyJacks do not. It makes removing the mainsail much more difficult, as it threads through the mainsail. It can cause chafe on the mainsail, and can't be pulled forward like lazyjacks can. It is a fairly expensive modification to the sail and topping lift.
I still prefer the simplicity of lazyjacks.
