green flash - Page 3 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
  #21 (permalink)
Old 05-05-2002
MaryBeth is on a distinguished road
green flash
The green flash is something used to impress new sailors, or at least those who have never sailed Atlantic offshore. It can also be used to keep morale up through bad weather, if the person does not know that it does not happen in a cloudy situation. Kinda gets everyone together just before sundown, makes for great dinner conversation, especially if you are expecting a fairly bad night and the weather is due to be bad for a few more days.
It does have to do with light refraction, I would expect. I have seen it 16 times now. Each time there were absolutely no clouds from horizon to at least directly overhead. In all the times I have watched the lovely Key West sunsets, and sunsets from the islands, rum punch in hand, I have not seen it from land.
When it does happen after you have played it up to people who have heard about it and think it''s not real, it is fantastic. Makes it even better.
So don''t stare yourself silly. If the weather is right it will happen. On the other hand, if you''re having a yucky trip and the people onboard have only heard a bit about it, it is a great conversation topic - diverts worry about the weather.
Mary
  #22 (permalink)
Old 07-26-2011
jmayton is on a distinguished road
I read some where that a pilot of a Blackbird spy plane extended the time of the "green flash" by flying towards the sunset and adjusting his speed to match. Not sure where I read that though so it could be apocryphal for all I know.
  #23 (permalink)
Old 07-26-2011
CaptainForce's Avatar
People are less likely to see the green flash if:
1) they spend time looking at the sun before the last remnant remains.
2) the horizon is disturbed with larger waves.
3) they expect a moment of brighter light. (it's quick, not intense)
4) the air is humid or hazy or clouds are present.
The spectrum is produced at the limb of the earth in the same manner that white light is refracted in a simple cardboard slit spectroscope. There is no special inversion or reflection of the spectrum and it can be seen on land with the requisite flat horizon such as salt flats or a flat plain. If you consider the visible light as red-orange-yellow-green-blue-indigo-violet; the middle segment (yellow-green-blue) can be briefly distinguished as the "green flash". Of course, we all easily see the early diffused red & orange, so nobody exclaims this "flash" and thoretically one could see the indigo-violet flash, but this requires an even greater sensitivity. The green flash phenomenon is clear and simple optical physics and no mystery. Take care and joy, Aythya crew
  #24 (permalink)
Old 07-26-2011
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
have seen the Green Flash in both the Atlantic and the Pacific Oceans. And a couple of times in the GoM. One aspect of the atmosphere, is that it has to free of pollutions and clear.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
  #25 (permalink)
Old 07-26-2011
CapnBilll is on a distinguished road
I have seen it just off of the coast of Uahu. The sky has to be clear of couds from you to over the horizon. Wait until just the second the sun sets. Lensing, (prism) from curvature of the ocean causes it. I can't see it from the gulf coast, (curvature of the land to the west blocks it). Key west should be able to see it on sunrise, but not on sunset.
The Sun has Risen on a New Day filled with the Promise of Adventure.
  #26 (permalink)
Old 07-26-2011
Rozz is on a distinguished road
ive seen it here a few times and my friend was able to get a pic of it one time when we were waiting for it on Sunset Cliffs. turned out great, she sent it to me. i will see if i can find it...
  #27 (permalink)
Old 07-26-2011
casey1999 is on a distinguished road
Hear in hawaii you can see the green flash probably 30% of all sunsets that occur over water (not land). What you need is no clouds where the sun is setting and a very clear visability (which hawaii normally has). Also it helps to be at an elevation of at least 20 feet above the earth or water surface (deck of a cruise ship works well). The higher up you are it seems to work better- I live at elevation 400feet and regularly see the green flash. Best to not look directly at the sun until it is just ready to entirely slip below the horozion. Then, for a split second just after the entire sun is gone you will see a speck of green for a split secon- the green flash. I could see how a plane flying west at a high altitude would extend the time of the green flash- it is extending the time of the sunset time.
  #28 (permalink)
Old 07-26-2011
I have never seen the green flash on a sun rise but have seen hundreds on a sunset- not shure why- maybe the dust generated by day helps generate the green flash.
  #29 (permalink)
Old 07-26-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
I'm stunned by the widespread phenomenon of computers on which the Google search feature is be disabled. I wonder if Google knows?
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
  #30 (permalink)
Old 07-26-2011
CatalinaRob is on a distinguished road
Although I have never seen a green flash I did manage to find some Google images here:
green flash - Google Search
Marinette to Fayette in Green Bay john_r Chartering 1 06-10-2003 05:30 AM
Green sailor needs advise on docking, an anchor......... sailingsundance Cruising & Liveaboard Forum 2 05-21-2003 12:15 PM
Green Water Cruising dtfm Cruising & Liveaboard Forum 3 09-25-2002 11:49 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
