01-07-2007
Owner, Green Bay Packers
Trueblue,
I believe that Rich's point was that the spade rudder is constructed in one of two ways; semi-balanced or balanced. In either of those constructions the rudder post is not at the leading edge of the rudder as it is in most skeg mounted rudders. The objective in balancing the rudder is to get relatively equal masses forward and aft of the rudder post. This eases the strain on all components of the steering system immensely. A rudder constructed in this manner turns almost as easily astern as ahead. The skeg hung rudder, when going astern, acts just like the door that got caught by the wind while open.
Pintles and gudgeons, regardless of mounting location are weaker than the rudder stock itself. With a balanced, or semi-balanced rudder the strain is transmitted via the rudder stock upwards to the bearing. The bearing and quadrant are mounted in such a secure way that no gudg/pint can be. As previously mentioned, the damage to the skeg hung rudder probably occurs more from being slammed over against the stops than the actual force of the water.
A balanced, but more commonly a semi-balanced rudder can be mounted to a skeg or the keel but it does take a little engineering.
