I would go with a bridle, but with each leg of the bridle attached separately, or two separate snubber
lines. The main reason I would do this is for redundancy. If either
line chafes through, the other should be able to hold the boat, provided you've attached them to a substantial enough hard point on the boat.—a mooring bitt or large
cleat with substantial backing, or preferably tied into the hull structure somehow.
The
line should be at least 30', but given the size of your boat, 75' might make more sense. If you have to let out some additional
rode, 30' really isn't long enough to accommodate that... where as snubbers that are 75' long would allow you to let out at least 40' additional
rode without having to remove the chain hook, which would require you to retreive the
rode to get the chain hook off.
POST.
