Go Back   SailNet Community > General Interest Forums > Seamanship
  #11 (permalink)
Old 11-17-2007
Tartan34C will become famous soon enough
A blood knot would work, but I'd use a Fisherman's Knot, which is basically an overhand knot tied around the standing part of each end. It uses less line than a blood knot and takes up less space.
Thats what I call a Double Fisherman's Bend and yes it would be the best knot. I added it as an after thought because my mind went blank and I could not think of its name at first.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
  #12 (permalink)
Old 11-17-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
A sheet bend is the simplest to use.
There are 10 kinds of people. Those who understand binary and those who don't.
  #13 (permalink)
Old 11-18-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
A double fisherman's bend takes another turn on each side, using a lot more rope. I just tried the (single) fisherman's bend and it looks like it'll do the trick. (You've got to get the orientation of each side right for them to jam well, tho.) Thanks for the idea, SD.
And thanks, everybody else, for your suggestions, as well.
Jim
s/v Abracadabra
1976 Pearson P30
  #14 (permalink)
Old 11-18-2007
No I dont remember
Raggbagger is on a distinguished road
What you really ought to use is the interwoven-doublebraided-triple slip-highland-twisted-haggis-bag-truckers hitch- sheep-shank-fraid-knot and should that fail go with the bowline.
Its hard trying to nap with that bilge pump alarm going off all the time
  #15 (permalink)
Old 11-19-2007
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I'm a fan of the sheet bend. Or a double sheet bend.
Merit 25 # 764 "Audrey"
  #16 (permalink)
Old 11-23-2007
TejasSailer is on a distinguished road
Just had a similar situation, and after tying a figure-eight bend recalled this thread. The application is running a new halyard and used the figure-eight bend to tie three consecutive rings of light line through the winch end of the halyard on which to tie the messenger line. There is also a similar figure-eight loop, but I used the bend.
  #17 (permalink)
Old 11-26-2007
tjhlll is on a distinguished road
Tartan34C
Is that you Mark Twain? Well said!
Seven Knots You Can't Live Without Sue & Larry Learning to Sail Articles 0 11-14-1998 07:00 PM
Seven Knots You Can't Live Without Sue & Larry Seamanship Articles 0 11-14-1998 07:00 PM
