Port vs. Starboard tacks - Page 2 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
  #11 (permalink)
Old 11-26-2007
Zanshin's Avatar
Zanshin is on a distinguished road
Mainsail is in-mast, so no drag difference whether furled or not. The headsail was reefed, so a 3-4cm rolled section would disturb the airflow more on starboard tack, but just the leading edge wasn't laminar - I would be amazed if this causes a difference of over 20% though.
I've just spent the past couple of hours trying to repair the work that the yard did on my ship At least I'm attached to power for the first time in a week and have the air cranking while I'm head down in the bilges.
  #12 (permalink)
Old 11-26-2007
Umm... if it is like other mainsail in-mast furling systems, it will be biased a bit to one side when reefed... and essentially centered when not reefed.. so it too may have had some effect on the performance, since the sail shape will be slightly different.
  #13 (permalink)
Old 11-26-2007
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
As others have suggested, use the GPS the next time conditions are good for a cross check. It the speed difference still exists, check the rig to make sure the mast is centered, is in column, etc. Yes, get a Loos gauge for the rig to check the stay tension side to side.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
  #14 (permalink)
Old 11-27-2007
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Originally Posted by Zanshin View Post
Y... I was using a log wheel, which is forward of the keel and only about 4 inches off the centreline (it is to port).
My log wheel is also offset and I get different readings on opposite tacks, though not as much as you are seeing. I theorise that, as the boat is (what's the word?) crabbing sideways while close hauled, especially in a seaway, the flow over the log wheel will be affected by the hull shape differently on either tack. GPS will give a good comparison but for any accuracy you really need recordings. Both the GSP and the log wheel electronics are averaging a series of measurements and pitching particularly introduces a different variation to both.
I think SD had a good point about the accuracy of the wind instrument, the head to wind setting has to match both the aerodynamic and hydrodynamic centre lines and the boat's centreline.
Starboard and Port tacks? ImASonOfaSailor General Discussion (sailing related) 45 07-02-2007 04:18 PM
Faster on Starboard than Port. Why? IrishMistRacing Racing 20 08-21-2006 09:35 PM
Sailing Basics Steve Colgate Learning to Sail Articles 0 03-09-2003 08:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 08:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
