Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
User Name
Old 09-17-2001
JEFryar JEFryar is offline
JEFryar is on a distinguished road
GPS ERROR
Is anyone else out there noticing how slow their GPS is in responding and the increase in error?
Old 10-01-2001
Westhaven Westhaven is offline
Westhaven is on a distinguished road
GPS ERROR
No!
But I suggest you check your GPS aeriel location (even wet sails can block gps signals) and is you datem on the GPS set correctly for the charts you are using.
Are your charts currenlty corrected?
Hope this helps.
Old 10-02-2001
GPS ERROR
Thank you "Westhaven"
I did a soft restart and it seemed to make all the difference..
Old 02-06-2002
davidk davidk is offline
davidk is on a distinguished road
GPS ERROR
Yeh, but did you all notice the increase in GPS accuracy post 9/11. Many thanks to the military!
Old 05-19-2002
TANGO3 TANGO3 is offline
TANGO3 is on a distinguished road
GPS ERROR
I use a Magellan 300M with WAAS accuracy built in. Today I had a chance to check it out and it was right on the money on the Chesapeake Bay near Annapolis. I have two units. The other is a Garmin 76 and it is in agreement to a couple of thousands with the Magellan. I was also wondering if post 911 the military had started degrading the signal again. It look like they haven''t. Anybody else have any info?
Jerry
Old 05-21-2002
MaryBeth MaryBeth is offline
MaryBeth is on a distinguished road
GPS ERROR
I don''t currently sail with a GPS on a consistent basis. I work in a boating supply store. Post 9-11 there was a bit of a delay in reading satellites. Then it got back to normal. Now, once more, there seems to be a bit of a delay. But, again, I am not using one daily, this is more on a twice a week or so showing of the products to customers. And, once obtained, the readings seem to be spot on, just takes a bit longer for even the best handheld units to recieve a triangulation.
So, will even itself out in the end, huh?
MaryBeth
Display Modes
vB code is On
I give up. That''s it. I quit. yandina Gear & Maintenance 16 03-31-2008 04:44 PM
Can''t view messages ct Buying a Boat 2 10-14-2003 09:59 AM
Can''t view messages ct Buying a Boat 0 10-13-2003 06:08 AM
Tiller auto pilots newuser Gear & Maintenance 8 01-21-2003 08:21 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
