Sab, I also have a bow first, starboard finger docking situation, with very little room between fingers and between our dock and the next dock (off my stern when docked), so it is a tricky slip. Also, I often have significant crosswind hitting the starboard beam, compounded by tidal currents. There are no
cleats on the dock to snag a
line or boathook (a springline would help, but not an option there).
Although I'm also only still learning, the technique that has worked best for me so far is:
1) I ensure that I have all
lines,
fenders and a boathook ready before I enter the marina.
2) I motor slowly, with my goal being about 0.8 knots as I reach my slip (fast enough to still have "way" and steerage, but slow enough that I can control/adjust and not hit the forward dock when I've entered the slip.
3) I have determined the best "line" to take in the channel before turning into my slip, that allows me to take about a 90 degree turn into my slip--depends on the turning radius of your boat (mine best
line is about 15 feet off the stern of the boats on my dock as I head down the channel toward my slip)
4) When I am 1 1/2 boats (about 15 feet) away from my slip I start my turn to starboard and put engine in neutral. The turn slows my speed somewhat as I enter the slip. As I enter, I turn the rudder slightly to port to stop the boat continuing to turn to starboard and bring the stern into the slip (ie. to straighten the boat in the slip).
5) If I have done all this correctly, I can now step off the boat (quickly) to grab
lines and secure them before the crosswind blows the boat away from the finger.
You'll note that by going at this speed, and only in forward, with only a simple turn into the slip, I didn't mention (and don't use) prop walk in any noticeable way to accomplish my docking. However, it is very helpful on my leaving my slip: I put the engine in reverse and give it a good bit of throttle which moves my stern to port (away from the finger) and backs me out of the slip. I put the rudder even more to port to back out further into the channel (like backing out of my driveway at home). When the boat is nicely centered in the channel, I put it into forward and drive out.
I would welcome any suggestions for improvement, but so far this works for me most of the time.
Frank.
