Cat vs Mono - Page 2 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
  #11 (permalink)
Old 03-07-2008
Catamarans also track better because they have two long narrow hulls, and in the case of some catamarans, multiple keels, which naturally resist turning. This is one reason they sometimes have trouble tacking. However, the sail plan still has to be balanced for them to sail optimally.
Originally Posted by Plumper View Post
Multihulls track better because they don't heel. The heeling moment on a monohull puts the center of effort out over the water and makes them want to turn. The center of effort stays over the boat (most of the time) in a multi. Balancing a multi is no effort. (point in their favour)
  #12 (permalink)
Old 03-07-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
You mean I can't just fly those dishrags any 'ol way I want and stay balanced?
I thought trimming sails was to make it fit the fore stay and the mast.
Gemini centerboards get popped and switched on a tack. If you pop the board prior to a tack the boat slides around pretty quick - the wee bit of lee way you make actually helps because you'll pick up speed that helps you carry through.
Gem 105's are damn near the optimum 9:1 length:beam on each hull, completely symmetrical (both hulls shaped the same). Once I'm trimmed up the only time I touch the helm is to hold myself up or turn to a new course.
Not germaine to the OP's question because the Admiral 38 has no boards.
The Lagoon 41, Voyage 44, Voyage 50, Maxim 38 - the multi's I've chartered, all handle pretty much the same - track straight once you get engine output balanced (not RPM, actual thrust); and are reasonable at tracking under sail if you can get the sails to balance out.
Cats on Board slosharron Living Aboard 42 09-25-2011 04:14 AM
mono to cat convertion jnanjorl General Discussion (sailing related) 6 02-20-2007 01:51 PM
Cat -vs- Mono ? jsgsail Boat Review and Purchase Forum 9 08-02-2004 08:54 AM
Mono or Cat henryvand Chartering 1 10-21-2002 08:38 AM
Finding the Family Boat Dan Dickison Buying a Boat Articles 0 09-05-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
