Originally Posted by sailaway21
Good article.
If I had to add anything to it or subsequent articles it would be a reference to what used to be called the General Prudential Rule, now covered under Responsibility, along with an emphasis on the nature of special circumstances where a departure from the Rules may be necessary. Most recreational boaters, even with knowledge of the Rules, do not know that more than two vessels involvement may make the case one of special circumstances for which the Rules do not apply. Perceiving one's self as the stand-on vessel in special circumstances can have consequences unforeseen.
I think that you mentioned that the Rules only apply to vessel's within sight of one another. If not, you should.
The only other topic I'd have you expand on is the requirement for action when in-extremis. In-extremis is defined as when the actions of the give-way vessel alone are insufficient to avoid collision. And the stand-on vessel is then required to take action as to best avoid collision.
Fine work, Yamsailor.
In-extremis is not used in the COLREGs anymore. It is a hold over from previous rules. Your definition is correct though.
So who is in extremis, the give way vessel or the stand on vessel? Perhaps from one of the vessels point of view the situation is not as critical. Before considering yourself in-extremis you should go through all the other phases (five short blasts with five flashes of light, calling on VHF, etc) then, if the other ship doesn't respond you can maneouvre to avoid collision. Before that the stand-on vessel is required to do just that.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
