Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
User Name
  #11 (permalink)
Old 04-01-2008
CharlieCobra's Avatar
CharlieCobra CharlieCobra is offline
On the hard
CharlieCobra has a spectacular aura aboutCharlieCobra has a spectacular aura about
I'd say the best tip is to never back down any faster than the speed at which you'd want to hit something.
  #12 (permalink)
Old 04-01-2008
Faster Faster is online now
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
While there's a certain logic to that, Charlie, often the boat will handle better at some speed, and be less susceptible to cross breeze effects etc.
I'm not suggesting you barrel in backwards at 5 knots, of course, but better than dead slow will usually get better results. The good news is that forward gear "brakes" are the most effective, even with a folding prop.
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
  #13 (permalink)
Old 04-01-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
You really need to watch the flow of water past the hull and not try steering until the boat is actually making progress through the water in reverse. The suggestion to use short bursts of power and leave the engine in neutral most of the time is one I'd highly recommend as well. Watch out for making too much speed in reverse, since as Bajamars points out, the rudder will usually load up and slam to one side or the other.
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
  #14 (permalink)
Old 04-01-2008
labatt labatt is offline
I'd rather be sailing
labatt will become famous soon enough
Labatt knows this because, as beautiful as she is, his boat is one of those that really doesn't like to back up straight !
Yep - Perry describes the keel on our Passport 40 as a slightly extended fin. I describe it as a full keel wannabee. Whatever it is, it hates backing up in a straight line, although using the burst/neutral method I can get decent steerageway.
s/v "Pelican" Passport 40 #076- Preparing to cruise - http://blog.svpelican.com
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
  #15 (permalink)
Old 04-02-2008
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
Basically, the boat went whereever it wanted with no regard whatsoever for the rudder or my screaming.
That is why we refer to boats as "she"
  #16 (permalink)
Old 04-02-2008
Amegednon Amegednon is offline
Amegednon is on a distinguished road
All sailboats have this problem more or less, in a tight spot in your marina speed my not be practical, prop walk and many short forward and backward manuvers maybe best. Your type of prop can have alot of effect, I find three bladed props have better backing ability than two bladed.
Display Modes
vB code is On
Steering System Spring Checkup Tom Wood Gear and Maintenance Articles 0 04-26-2004 09:00 PM
Steering System Spring Checkup Tom Wood Her Sailnet Articles 0 04-26-2004 09:00 PM
Checking the Wheel Steering System Will Keene Gear and Maintenance Articles 0 07-31-2002 09:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 08:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
