a couple of posts above bobwebster wrote:
"The islands on the screen are the only ones there, but you're right. The shape on
radar does not precisely agree with the map. "
The "shape" of an island on a chart will hardly ever match the shape of the island on
radar because the chart is a vertical depiction and the
radar is much more of a
line-of-sight or horizontal view of the geography. When intrepreting a
radar return you have to remember that it's reflected energy you're seeing. Energy goes out and reflects back only from solid surfaces in the direct path of the
radar beam. If an island has a higher shoreline (hills or mountains) on the side from which you're approaching that's probably all you will see on the
radar -- the shoreline. You can't "see" on
radar any of the land mass that's 'behind' the hill, just as you can't see it with your eyes.
It is true that the general shape of a shoreline shown on
radar will match fairly closely the shape of the near shore on the chart (i.e. where land meets water), but don't expect the overall shapes of charted land masses to look similar to their
radar returns.
The fact that the returns shown on Bob's chart plotter (copied above) look like several islands rather than two is most likely due to the contours of the two islands. High elevations on the near shore with an even higher elevation on the other side of the island with a valley in between will appear on the
radar screen as two distinct returns. Looking at it with an eyeball from a distance it will appear as one land mass, while on
radar it appears as two -- because at a distance you eyes can't discern the difference in ranges of the two high elevations while the
radar can.
That said, the returns shown on Bob's chart plotter do look a little strange. It' probably has to do with the way the signal is refined and presented in the display. I have no experience with these "combined" displays and like one poster above, I'm not a fan of this integration of technology. When intrepreting
radar I much prefer to use a tuneable CRT screen designed specifically for displaying
radar returns. I also find that the land contours shown on many old fashion paper
charts are very helpful in intrepreting what the
radar's showing you.
