Originally Posted by hellosailor
So apparently Admiralty Chart Datum (ACD) is known to be offset from WGS84 and should not be expected to agree with GPS positioning. Did Navionics ever give you an answer?
I never did get an answer from Navionics.
The OSGB coordinates at this location are about .3 mile different from the WGS84 coordinates, which is a large difference. However, that does not explain the 1+ mile error or the fact that the Navionics data uses WGS84 and has the same error.
I decided to get to the bottom of this. Unfortunately, Google Earth doesn't show the Marietas.
However, in 2000, the space shuttle Endeavor did a
radar elevation survey of the earth from 60N to 56S. You have to set some parameters, but if you go to
The National Map Seamless Server you can see the locations of Marietas Islands and their lat-lon, as seen by the shuttle's
radar.
Here's the screen image, with an arrow I added to show the lat-lon I requested:
http://xpda.com/minnow07/marietas/marietasSRTM.png
The lat-lon agrees with islands' location in the boat's
radar, and not with the Navionics data:
http://xpda.com/minnow07/marietas/P1150869.jpg
The paper
charts agree with the Navionics data. In other words, the paper
charts (except for Rains's Mexico boating guide), Navionics data, and Maxsea data are off by more than a mile, even taking into account various chart datums.
I tellya, those islands are in the wrong place!
I have seen a few other "interesting" features in
GPS data. For example, once I was flying off the coast of Alaska. The
Garmin GPS showed only blue water to my right, but there was an island several hundred feet tall there. I notified
Garmin but didn't hear back.
