You state that "Today''s
charts are far better than those used in the past." Not always true. Check your chart and you will find that many of the surveys used were performed years ago. This is a good reason not to rely on electronics without a healthy dose of common sense. One of the problems now is that a
GPS is often more "accurate" than the chart, so we sail blithely on unaware of the rock about to rip our bottom out. No matter what method used,
GPS or sextant, we must always be aware of what''s around us and exercise caution. Belts and suspenders ain''t all bad, so why not have all reasonable tools on board for safety? If you are coastal cruising, up to date
charts, tide tables, good
compass, etc. are probably sufficient, assuming you can take bearings. If you are offshore, redundancy, including electronic and nonelectronic means of navigating, should be the standard. After all, it''s only your life you''re gambling with, right?
