Tomarto, tomayto - why argue about this? Each sailor has his chosen way. To call someone an idiot because he doesn't do things the same as you is just plain silly. Anyway, consider the following:
I have single-handed across the Indian Ocean, had 3 h/h
GPS receivers and all the required CN stuff on board. I never had even one time in three months of sailing that I never got a decent
GPS fix (Garmin Map76). I messed with the sextant when I was bored and never got to within 30 miles of the
GPS location. I never had to use the other two receivers. I really envy the guys who can get down to half a mile with a sextant although I've never personally seen it done.
Most
GPS units today are absolutely moisture proof, if yours isn't get a new one, it won't corrode internally. And like one of the other respondents said, don't use batteries, plug into the domestic electrics. Keep your AA batteries for the unlikely event that your wind gen fails, your solar panels die, your gen set won't start and the engine alternator goes belly-up all at the same time causing your domestic electrics to go flat. Talk about doom-prophets!!
CN is sometimes not possible for days, even weeks because of cloud cover. How long is the longest period anyone has experienced a
GPS downgrade for? And when you're in the middle of the ocean, how far out relatively would that place you?
I treat my
GPS like I treat my sextant. I use it to get a fix and at all other times it is in a safe location under my chart table. Damage it? No way!
And a lightning strike that's bad enough to take out my
GPS in the locker will probably leave me with bigger problems than my current location.
Oh, and by the way, when your chronometer stops working, use the clock on your
GPS reciever, it's pretty accurate.
Lastly, one of the most important issues about coastal navigation with
GPS is that the
GPS is probably far more accurate than the chart you're using so be sure to look out the window when you're navigating close quarters. It probably won't be your
GPS that runs you aground, it'll be the reef that isn't exactly where the chart says it is.
And finally, lastly, never go to sea without paper
charts for every possible destination on your route. And if you're going coastal, take a local Pilot with too!
Thanks for the chat
