Go Back   SailNet Community > General Interest Forums > Seamanship
  #11 (permalink)
Old 08-06-2008
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Notatom has the gist of it totally. Rule 19 in fog. And all sections of it and rule 5 apply.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
  #12 (permalink)
Old 08-12-2008
RichNH's Avatar
RichNH is on a distinguished road
How much would a 25' aluminum mast stand out on radar?
  #13 (permalink)
Old 08-12-2008
Basically, an aluminum mast has almost no radar profile. Radar needs flat surfaces, corners and edges to reflect off of, and most masts have little in the way of large flat surfaces, hard corners or edges.
  #14 (permalink)
Old 08-12-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Originally Posted by camaraderie View Post
While both share some portion of the blame, I believe the catamaran has the legal duty to avoid a vessel actively fishing.
Gee, CAM, you can't find a way to blame the Democrats for this one?? you're slipping!!!!
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
  #15 (permalink)
Old 08-14-2008
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
If the mast has no reflection then where is his reflector, or reflectors? I will occassionally call a freighter to see if I am clear on his screen. The thunderstorms that roll through southern Florida can be as bad as fog.
  #16 (permalink)
Old 08-15-2008
Rockter will become famous soon enough
Here lies the body of Ezra Gray,
Who died maintaining the right of way.
He was right, dead right, as he sailed along,
But he's just as dead as if he'd been wrong.
Anon.
Works for motorcycles too, with a change from "sail" to "rode", and for cars with a change to "drove".
  #17 (permalink)
Old 08-15-2008
Unfortunately, the Big Boat rule applies more often than not.
  #18 (permalink)
Old 08-15-2008
OZBOATIE is on a distinguished road
The following is an extract from the Colregs
Part B - Steering and Sailing Rules
Section 1 - Conduct of vessels in any condition of visibility
Rule 5 Look out.
Every vessel shall at all times maintain a proper look-out by sight and hearing as well as by all available means appropriate in the prevailing circumstances and conditions so as to make a full appraisal of the situation and of the risk of collision.
This rule has as consequence that all solo sailing for long trips is against the COLREGS as there is no look-out when the skipper is sleeping. Apparently the risk is tolerated, but it remains that most authorities insist on a proper look-out, and check it was effectively carried out after an incident. In spite of this the look-out duties are more and more neglected on many ships.
So who was not keeping lookout is on the wrong end
  #19 (permalink)
Old 08-15-2008
Motoring under autopilot in the fog with the bridge left unattended is a bigger problem than not just keeping a good lookout imho.
Rule 5 Look out.
  #20 (permalink)
Old 08-15-2008
Karletto's Avatar
Karletto is on a distinguished road
Originally Posted by theartfuldodger View Post
all 8 on the catamaran were put into the water.
all 8 on the cat have fallen overboard??!! it must had been an open cat, a small recreational cat, with no fence around the deck but its true that in fog everyone on board is on high alert and standing
where's the outrage now? sck5 Off Topic 138 03-21-2008 06:26 PM
The perfect woman !!! Robby Barlow Off Topic 124 02-19-2008 09:43 AM
Basic Electrical Diagram tsweeney Gear & Maintenance 20 02-15-2008 06:50 PM
Major Problems With Marina hamiam General Discussion (sailing related) 33 11-28-2007 04:33 PM
George Bush meets with Iran! Cruisingdad Off Topic 111 05-27-2007 11:57 PM
